It could be that but chances are that one of your control arms might need to be replaced soon.![]()
I need some help. What could be causing a click sound coming from the front drivers side. I have a 2002 1.8T sedan. Drive shaft???? Thanks in advance
Check out some of my vortex feedback: http://forums.vwvortex.com/showthread.php?952415
Ive got the same issue with on/off throttle. Boots are good but I hear the joints can go bad anyways internally. Going to try to get down to my buddys shop and get in on a lift to look. Along with the shuddering under acceleration i might be buy new shafts this weekend
if it "clicks" then id lean towards axle! if it "clunks" then id say ball joint/suspension related issue!
FMIC, Forge Hybrid splitter BOV, Motegi 17x7's in Pirelli p6, Eibach pro kit w/ sway bar, Kinetic slotted & drilled rotors, custom short throw, Glow Shift boost gauge w/ NSP steering column pod!
there are plenty of threads on diy on axle replacement! just search and youll def find one!
