Check the throttle closed switch on the bottom of the throttle body to see if its come loose.....if "warms up" means about 5-7min then check the Aux Air Regulator for proper operation....also are the ECU/02 sensor ground wires still under the bolt on the Cold Start Valve blockoff plate ???
