Test your battery...
#1
So over the last couple weeks my 03gli 24v vr6 has been acting strange. The at temp is close to 100 degrees so I've been driving with the ac on. After driving about 20 miles the car will for a second act like it wants to die and the abs light will come on and the radio will reset and then it will run fine. It does it intermittently when driving down the road and shifting from first to second. It did today die one time at a light. When I started it back up the clock on the dash had reset itself. If anyone can help I'd really appreciate it. Thanks
#3
Kool Haus ORIGINAL I took a crap at the kool haus before you even knew about it.
