Results 1 to 20 of 20
Thread: Steering Wheel Noise
  1. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    05-02-2012 07:49 PM #1
    Anybody else have a slight "whirring" or "scratching" sound when turning the steering wheel?
    Definitely inside the car.
    Took it to my dealer before and thought it was the clockspring (issue with the B6 Passats)....so they replaced it under warranty
    Well my car was still doing it.
    Took it back to them today and they said that they checked 3 other CC's on the lot and they all made the same noise.
    It's not the plastic rubbing either, on the wheel & the column trim.
    So they called VW's Tech Line, and they told the dealer that "this is an unwanted characteristic of the vehicle", AND that "no fix is available as of yet for this concern."
    VW: We know it's an issue, but we're not doing anything about it at this time.
    Really?
    2013 VW
    Dec 15th, 2009
    Bay Area, CA
    2009 CC Sport, 2.0T, 6MT, Iron Grey, Tinted Windows, VW DG Sport Springs, APR Stg I, Carbonio Stg I
    05-02-2012 08:52 PM #2
    Quote Originally Posted by snobrdrdan View Post
    Yes, I believe I have that. A kind of mechanical sound coming from the steering column. I always attributed it to the electromechanical steering. "Unwanted characteristic"? Not really. It is hardly ever quite enough for me to hear it. As long as it is "normal", it is fine.
    2009 2.0T, 6MT, Iron Grey Metallic, Tinted Windows, Blue Tooth, APR Stage I, Carbonio Stage I, VW DG Sport Springs
    Audio setup: Focal 165 KRX2 in the front (crossovers removed) powered by Rockford Fosgate T400-4 (one channel per speaker); ARC Audio KAR 265 in the rear powered by Alpine PDX-4.100 (bridged); 8" 250W Powered Bazooka Sub; RF 360.2 Digital Signal Processor
    Apr 28th, 2008
    In a house
    2012 CC Rline Candy White
    05-02-2012 08:54 PM #3
    I have that noise too....dont know what it is. I can only hear it when I am making a sharp turn, or backing up.
    Sent from my big a$$ galaxy Note 2
  4. Member dav1d's Avatar
    Mar 27th, 2011
    MK6 GTI 2D CW DSG
    05-02-2012 08:57 PM #4
    I hear it too in my GTI. My '06 BMW started to make the same noise but not until later in its life
    H&R cup kit - H&R 24mm RSB - APR Stage 1 - oem mud flaps - misc vag work - magnaflow cbe - neuspeed pflo (red) - piaa ion crystal fogs - piaa wedge bulbs - clear side markers - euro switch - alpine amp + lc2i
  5. Junior Member
    Jun 11th, 2008
    Tampa, FL
    2004 Phaeton; 2006 Jetta, Pkg 3 (traded for); 2012 CC RLine; 2012 Passat SEL
    05-02-2012 09:09 PM #5
    My dealer told me, the day I bought the car, "The sound you are hearing in the steering wheel is characteristic of the CC so don't bother bringing it back to be fixed because they all do it!"
  6. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    05-02-2012 09:15 PM #6
    I only notice it in the morning & when it's cold, when I'm leaving work.
    If it's normal...yeah, I'm okay with it.
    It's not that bad.
    I guess I'm just set off by the fact that it's "unwanted", but VW gladly supplies us with it
    2013 VW
    Mar 10th, 2009
    2006 Passat 2.0t 6mt
    05-03-2012 12:59 AM #7
    Its the clockspring. The problem is replacing the clockspring with a new one doesn't always help the issue. It started to be more noticeable on 2009+ cars.
    My buddy and I took a clock spring out and put the steering wheel back on. No more noise. We put the new clock spring in and started to make noise again. Use to work at VW. Wish I could help ya more. Sometimes after abit of wear they stop noise.
    Nov 27th, 2009
    50 Miles South of Tucson AZ
    2013 CC and 2009 Eos
    05-03-2012 02:02 AM #8
    After 32,000 miles it is still doing it.
    The sound is the same now as it was when new. I'm not worried.
    2013 CC Sport Plus, K@N Air Filter, LED Interior Lighting Including Foot Wells, 18" Interlagos Wheels w/ Cooper tires.
    2009 Eos, Tech Package, RNS510, K&N Air Filter, Silver/Black Leather Seats, Sherwood Aluminum Dash Kit, LED Interior Lighting, Underbody LED Safety Lighting, Under Seat Drawer.
    Dec 1st, 2009
    2010 CC 2.0T 6spd, 2012 CC Lux+ DSG, 2001 Corvette 6spd Z51
    05-03-2012 09:47 AM #9
    The whirring noise is the toothed-belt drive belt between the electric power steering motor and the rack. Normal for this design.
  10. Moderator rich!'s Avatar
    Feb 18th, 1999
    SoFLA
    '12 Touareg, '12 CC
    05-03-2012 09:53 AM #10
    when it goes out - you'll know. it will make a grinding noise and will occasionally lock the steering wheel upon vehicle start-up. (had the entire rack replaced)
    .: FireVortex the Browser Extension for VWVortex :: Download now for Firefox & Google Chrome :: Powered by etivite
    .: Features: Full Ignore a Member :: Thread Previews :: Kill Threads :: Products Search :: Quick Menu (favorite forums, subscribe topics, recently viewed) :: Custom Emoticons :: Quick Reply :: Full Screen Mode :: MyPage :: Kill Quoted Images :: Kill Quotes in Sigs :: more...
  11. Member
    Mar 10th, 2009
    05-03-2012 12:29 PM #11
    Quote Originally Posted by rich! View Post
    Yea, I have only seen one rack replaced myself.
    I guess also to remind him in case it fails during driving it won't lock up but will feel like power steering pump has gone out.
    snobrdrdan:
    As I said most of the time its the clock spring. Before I jump out on the limb does the noise come from the steering column near cruise control and turn signal stalks or at the base of the steering column near the firewall?
    Nov 27th, 2009
    05-03-2012 03:06 PM #12
    Quote Originally Posted by Boosted2003! View Post
    snobrdrdan:
    The noise that is being referred to on this post is coming from the steering wheel near the control stalk.
    Most, if not all CCs, have this sound.
    Like I said with mine, it's the same now, 32,000 miles later, as it was when the car was brand new.
    No big deal.
  13. Member
    Mar 10th, 2009
    05-03-2012 10:52 PM #13
    Quote Originally Posted by DavidPaul View Post
    No big deal.
    Yea, almost every CC I drove when I worked at a dealership I recall hearing this noise as well. 2010 B6 Passat did it as well.
  14. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    05-05-2012 05:41 AM #14
    It's near the steering wheel/stalk that it does it
    I'm not too worried about it anymore....since it's just a little noise & everyone else has it too
    2013 VW
  15. Member VWFSIB6's Avatar
    Jun 12th, 2007
    VW CC, Suzuki SV650S
    08-08-2012 01:24 AM #15
    is this the noise you guys are experiencing??
    http://www.youtube.com/watch?v=tT7B8E3_N6c&feature=plcp
  16. Junior Member
    Jul 17th, 2012
    Everywhere
    09 CC VR6 Sport
    08-08-2012 09:18 AM #16
    Mine does this as well. Sounds like rubber rubbing together or something.
    -Xklusiv
    09' CC VR6 Sport
  17. Member sfccryder's Avatar
    Nov 24th, 2009
    Castro Valley, CA
    2010 VW CC Sport 2.0T 6M
    08-08-2012 05:14 PM #17
    Quote Originally Posted by VWFSIB6 View Post
    that is not normal, my cc makes no sound at all. that would drive me crazy.
    i'd take it in and have them fix it.
    Island Gray Metallic 2010 CC Sport 2.0T 6M, APR Stage1, R-Line Sport Pedals, HTTRS-256-MA:M
    235/35/19 Hankook Ventus V12 K110's, Borla CBE, Koni ss coilover kit, Adams slotted/drilled rotors, with Stop Tech pads.
  18. Member GeoVDub's Avatar
    Oct 17th, 2011
    Northern IL
    2013 VW CC 4Motion
    08-09-2012 04:53 AM #18
    All of these 2013 'car died' and 'steering wheel' issue threads actually made me go inquire with my SA if they'd seen/heard anything from other CC owners in the area. Nothing yet, hope it's just a fluke that a few folks here had them...
    2013 Black CC 4Motion | Mods: Titanium Black Interior | Hartmann 256-GA:M 19"
  19. Junior Member
    Jul 3rd, 2012
    West of Boston
    2013 VW CC Sport, 6spd MT
    08-09-2012 05:57 AM #19
    Quote Originally Posted by Xklusiv View Post
    Mine too, but only when the car is stationary, and I assume when power assist is at it's highest.
  20. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    08-11-2012 06:26 AM #20
    The noise that I had on my '11 when I started this thread.....still there on my '13
    2013 VW
