Page 1 of 11 1 2 3 4 5 ... LastLast
Results 1 to 35 of 384
Thread: fs: 2004.5 jetta Gli 1.8 turbo part out
  1. Former Advertiser
    May 2nd, 2012
    So-Cal
    03 Gli & B5.5 passat
    05-02-2012 08:38 PM #1
    parting out 2004.5 GLI 1.8 turbo with 6 speed transmission
    driver side aluminum pedals
    DSC01646
    items not pictured below
    Window Motors 20$
    side mirrorsw/glass 50$ each
    Abs pump 120$
    doors in black magic pearl 180$
    Aluminum Foot pedals 100$
    stock amp 40$
    IMG_0353
    body locks 20 for set
    IMG_0358
    Headliner
    Headliner 80$
    sunroof controls 40 $
    sunroof motor 30$
    sunroof cloth 25$
    lights 13$ each
    DSC01645
    b pillars
    DSC01647
    body panels
    drivers door $180
    drivers rear passenger door $180
    passenger door $180
    passenger rear door $180
    wiper motors 40$
    side mirror plastic w/0 glass 25 each
    glass 30
    window motore $25 each
    side markers in fender 5 $ each
    trunk shock 40 set
    IMG_0357
    rear bumper supports
    IMG_0356 parts you dont see listed
    if interested in any parts
    contact us at (646) 752-0100
    ko3s with 400 miles almost brand new
    IMG_1274
    aftermarket manifold
    IMG_0957
    Fuel Pump 120$
    IMG_0314
    battery tray 20
    IMG_0230
    2004.5 Gli engine mounts replaces 11,000 miles ago $40
    IMG_1364
    1.8 turbo 6 speed clutch and pressure plate $ 150
    DSC01381
    battery holder 25$
    IMG_1386
    passenger Airbag 150
    DSC01379
    center console with crack on plastic 140
    IMG_1301 slight crack on plastic 140
    6 speed shifter 40
    IMG_1308
    rear view mirror GLI 30$
    IMG_0317
    aluminum trim $200 radio $40 hvac control $30
    DSC01227
    power steering resevoir 10
    IMG_1356
    brake cylinder 80
    IMG_1353
    side marker 1IMG_03285$
    wiper motor $40
    IMG_1294
    headlight control,esp control & rear defroster switch $ 10 each
    IMG_1381
    vents $10 each
    IMG_1382
    rear view mirror $25
    IMG_1385
    battery tray $20
    IMG_1386
    engine mounts $ 40
    IMG_1364
    Gli center console with crack on plastic $120
    IMG_1301
    window motors
    IMG_0231
    controls 10 $ each
    IMG_0273
    Abs pump
    IMG_0285
    sunroof controls
    IMG_0284
    Hood Hinges $20 set
    IMG_0324
    02 sensors
    IMG_0300
    airbag
    IMG_0299
    Sparco steering Wheel w/quick release in primer
    IMG_1128
    Sunroof/sunroof motor/headliner insert
    DSC01228
    jetta GLI grill minus vw sign
    IMG_1355
    heated seat rear defroster
    IMG_0273
  2. Member NYEuroTuner's Avatar
    Feb 4th, 2008
    SoCal
    Eleanor B5 S4 <3
    05-02-2012 09:45 PM #2
    BUMP
    -George
    SEMPER FI
    FACEBOOK
    AbsolutEuro.com <-- Psst Click me
    We Screw, We Nut, We Bolt
  3. Junior Member
    Apr 24th, 2010
    SOMD
    MK5 GTi MK3 8v Jetta
    05-02-2012 10:05 PM #3
    Oil pan?
  4. Former Advertiser
    May 2nd, 2012
    So-Cal
    05-02-2012 10:06 PM #4
    oil pan for 1.8 turbo?
  5. Member 1.8T_Guy's Avatar
    Feb 8th, 2011
    Brooklyn Park, MN
    02 GTI 1.8T
    05-02-2012 10:33 PM #5
    how much for the Ko3?
    Pushing 20V at a time
  6. 05-02-2012 10:50 PM #6
    how much for the front two door speakers shipped to 11580
  7. Former Advertiser
    May 2nd, 2012
    So-Cal
    05-02-2012 10:59 PM #7
    Quote Originally Posted by 1.8T_Guy View Post
    turbo is 400
  8. Former Advertiser
    May 2nd, 2012
    So-Cal
    05-02-2012 11:00 PM #8
    Quote Originally Posted by mr 2point oh View Post
    door speakers are 10 dollars each. plus shipping which is ten dollars so comes to a total 30 dollars shipped
  9. 05-02-2012 11:24 PM #9
    Consider it sold.
  10. 05-03-2012 01:31 AM #10
    Steering angle sensor avail?
    Tri-state VAGCOM DIAGNOSTICS l File Tweeking l Repairs & Installs l Custom AUDIO
    For Sale Items, OEM & Aftermarket parts
  11. Former Advertiser
    May 2nd, 2012
    So-Cal
    05-03-2012 01:52 AM #11
    Quote Originally Posted by mktooo View Post
    let me check on the availability of the sensor and ill respond tommorow thanks
  12. Member hfiles2011's Avatar
    Dec 5th, 2011
    MD
    00 VW Jetta 2.0L AEG
    05-03-2012 05:01 AM #12
    steering wheel is a good deal bump
  13. Former Advertiser
    May 2nd, 2012
    So-Cal
    05-03-2012 10:02 AM #13
    Quote Originally Posted by hfiles2011 View Post
    Thank You Sir
  14. 05-03-2012 10:32 AM #14
    ok let me know on the steering angle sensor asap..
    you have the steering column lower cover?
  15. Former Advertiser
    May 2nd, 2012
    So-Cal
    05-03-2012 12:38 PM #15
    i checked our inventory and we do not have the steering angle sensor. we do have the lower steering column cover .
  16. Member
    Feb 18th, 2010
    Avon Park, Fl
    2002 Jetta 1.8T tippy
    05-03-2012 02:22 PM #16
    Do you have sunvisors left? PM me please shipped to 98372
  17. Former Advertiser
    May 2nd, 2012
    So-Cal
    05-03-2012 03:49 PM #17
    pm responded
  18. 05-03-2012 08:20 PM #18
    how much for aluminiums brushed trims ??
  19. Former Advertiser
    May 2nd, 2012
    So-Cal
    05-03-2012 09:06 PM #19
    Quote Originally Posted by samvrfil View Post
    remaining is the aluminum trim around radio for 200 and center console piece for 140..if purchased together i can make it 300 even
  20. Junior Member mygreygli's Avatar
    Apr 21st, 2012
    New Jersey
    03 vw gli
    05-03-2012 09:50 PM #20
    hey do u have the drivers side rear door lock actuator ? and right rear speaker and tweeter?
  21. Former Advertiser
    May 2nd, 2012
    So-Cal
    05-04-2012 01:15 AM #21
    Quote Originally Posted by mygreygli View Post
    i believe we have those in stock.let me check on the items in the morning and get back to you if thats okay?
  22. Member rawk's Avatar
    Jul 29th, 2000
    Eastern CT
    91 GTI ABA-T, 01 GTI VR6
    05-04-2012 06:48 AM #22
    I'll take the 2 Sunvisors, PM'd you
    ** VW/Audi Mechanic - Mods, Maintenance, etc. - Reasonable Rates - PM for Info **
    91 GTI ABA Turbo Build Thread
    G Guitars - Effects Pedals for the Masses!
  23. Former Advertiser
    May 2nd, 2012
    So-Cal
    05-04-2012 10:37 AM #23
    Quote Originally Posted by rawk View Post
    pm responded
  24. Former Advertiser
    May 2nd, 2012
    SoCal
    B5 S4
    05-04-2012 04:34 PM #24
    BUMP
  25. Former Advertiser
    May 2nd, 2012
    So-Cal
    05-05-2012 11:34 AM #25
    bump
  26. Former Advertiser
    May 2nd, 2012
    So-Cal
    05-05-2012 03:17 PM #26
    bump
  27. Member
    Aug 3rd, 2011
    203 CT
    05-05-2012 03:30 PM #27
    how much for the sunroof control and sunroof shade/cover slider? PM me if you dont mind
  28. Former Advertiser
    May 2nd, 2012
    So-Cal
    05-05-2012 05:18 PM #28
    Quote Originally Posted by bouncyballs228 View Post
    pm replied
  29. Former Advertiser
    May 2nd, 2012
    So-Cal
    05-06-2012 12:12 PM #29
    Bump
  30. Former Advertiser
    May 2nd, 2012
    So-Cal
    05-06-2012 07:30 PM #30
    bump
  31. Former Advertiser
    May 2nd, 2012
    So-Cal
    05-07-2012 01:39 PM #31
    bump
  32. Member .:RyouExperienced's Avatar
    Sep 19th, 2005
    Santa Barbara
    1.8 big T Jetta
    05-07-2012 04:32 PM #32
    How much for a bumper grill insert on the drivers side? Is the battery cover damaged at all? Thx
  33. Junior Member
    Apr 15th, 2012
    Brampton, Ontario
    2005 Volkswagen Jetta GLS 1.8T
    05-07-2012 05:39 PM #33
    How much to ship the rear view to Toronto Canada?
  34. 05-07-2012 06:10 PM #34
    oh ****! able to ship the headliner and sunroof insert? to maryland?
  35. Former Advertiser
    May 2nd, 2012
    So-Cal
    05-07-2012 06:12 PM #35
    Quote Originally Posted by TunaSalad View Post
    sure ill private message u prices
