Results 1 to 3 of 3
Thread: 2010 TDI O2 Sensor issues... Vag scan included
  1. Member E30Bimmer's Avatar
    Jul 6th, 2008
    99' E430 Sport
    05-02-2012 10:18 PM #1
    2010 TDI has had O2 Sensors replaced and even the ECM due to dead signal on Pin 9. The car is still showing a glowplug light and pulling up codes. This is the most recent scan @ only 52k.
    Could this be a faulty harness at this point?
    Thanks for any and all help!
    Wednesday,02,May,2012,21:52:31:41796
    VCDS Version: Release 11.11.3 (x64)
    Address 01: Engine Labels: 03L-906-022-CBE.clb
    Control Module Part Number: 03L 906 019 CL HW: 03L 906 022 TS
    Component and/or Version: R4 2,0L EDC G000SG 7274
    Software Coding: 0050072
    Work Shop Code: WSC 08340 444 83921
    VCID: 77F6FBCB06D6651
    5 Faults Found:
    001035 - Exhaust Gas Recirculation Temperature Sensor A
    P040B - 000 - Implausuble Signal
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 84175 km
    Time Indication: 0
    Freeze Frame:
    RPM: 138 /min
    Speed: 0.0 km/h
    Voltage: 9.65 V
    Temperature: 19.8°C
    Temperature: 78.0°C
    Temperature: 78.0°C
    Temperature: 18.0°C
    008241 - Exhaust Gas Temp Sensor; Bank 1 Sensor 2
    P2031 - 000 - Electrical Malfunction - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 2
    Fault Frequency: 5
    Mileage: 84330 km
    Time Indication: 0
    Date: 2019.14.25
    Time: 22:16:07
    Freeze Frame:
    RPM: 1909 /min
    Speed: 74.0 km/h
    Voltage: 14.21 V
    Temperature: 80.1°C
    Temperature: 930.0°C
    001348 - Sensor 1 for Exhaust Temp Bank 1 (G235)
    P0544 - 000 - Circuit Malfunction - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Mileage: 84330 km
    Time Indication: 0
    Date: 2019.14.25
    Time: 22:16:13
    Freeze Frame:
    RPM: 2070 /min
    Speed: 81.0 km/h
    Voltage: 14.14 V
    Temperature: 81.0°C
    009258 - Exhaust Gas Temperature Sensor; B1 S3
    P242A - 000 - Malfunction - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 84330 km
    Time Indication: 0
    Date: 2019.14.25
    Time: 22:16:13
    Freeze Frame:
    RPM: 2461 /min
    Speed: 66.0 km/h
    Voltage: 14.06 V
    Temperature: 54.0°C
    009326 - Exhaust Gas Temperature Sensor 4 Bank 1
    P246E - 000 - Electrical Malfunction - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 84330 km
    Time Indication: 0
    Date: 2019.14.25
    Time: 22:16:13
    Freeze Frame:
    RPM: 2461 /min
    Speed: 66.0 km/h
    Voltage: 14.06 V
    Temperature: 54.0°C
    Readiness: 0 0 0 0 0
  2. Junior Member
    Jan 21st, 2010
    2010 Audi A3 TDI
    05-03-2012 05:23 PM #2
    IIRC, there was a TSB on the O2 sensors; has it been done?
    Nov 22nd, 2005
    2001 Jetta TDI; 2009 Jetta TDI Sportwagen
    10-13-2012 11:20 AM #3
    Quote Originally Posted by E30Bimmer View Post
    5 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 84175 km
    Time Indication: 0
    Freeze Frame:
    RPM: 138 /min
    Speed: 0.0 km/h
    Voltage: 9.65 V
    Temperature: 19.8°C
    Temperature: 78.0°C
    Temperature: 78.0°C
    Temperature: 18.0°C
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 5
    Mileage: 84330 km
    Time Indication: 0
    Date: 2019.14.25
    Time: 22:16:07
    Freeze Frame:
    RPM: 1909 /min
    Speed: 74.0 km/h
    Voltage: 14.21 V
    Temperature: 80.1°C
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Mileage: 84330 km
    Time Indication: 0
    Date: 2019.14.25
    Time: 22:16:13
    Freeze Frame:
    RPM: 2070 /min
    Speed: 81.0 km/h
    Voltage: 14.14 V
    Temperature: 81.0°C
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 84330 km
    Time Indication: 0
    Date: 2019.14.25
    Time: 22:16:13
    Freeze Frame:
    RPM: 2461 /min
    Speed: 66.0 km/h
    Voltage: 14.06 V
    Temperature: 54.0°C
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 84330 km
    Time Indication: 0
    Date: 2019.14.25
    Time: 22:16:13
    Freeze Frame:
    RPM: 2461 /min
    Speed: 66.0 km/h
    Voltage: 14.06 V
    Temperature: 54.0°C
    Any luck with this? I have a fault P242A and have the
    sensor 03L-906-088-T
