Bump
#1
parting out 2002 vw jetta Gli 6 speed
parts not pictures
window motors 20 each
airbags 100 each
relays 20 each
coolant resevoir 10$
alternator 40$
fuse panel 30 $
trunk hinges 30$ set
abs pump 100 each
airbag control module 120
speakers 10 each
ecu holder 10
dash pieces
24 valve ecu 6 speed car 120$
headliner/interior
grab handles $10 each
sunroof switch 30$
Seat belts
visors 25$
lights in rear passenger 15$
A pillar- $30 for the pair
B pillar- $40 for the pair
C pillar- $50 for the pair
body panels
drivers door $180
drivers rear passenger door $180
passenger door $180
passenger rear door $180
wiper motors 40$
side mirror plastic w/0 glass 25 each
glass 30
window motors $25 each
side markers in fender 5 $ each
door locks 20$set
6 speed with 98,000 miles $1000
24 valve oil filter housing
24 valve coil pack
ks
bumper supports 20$
tailights $60
rear main seal 15$
Abs pump
passenger airbag 120$
6 speed shifter 60$
glovebox light 20$
m.a.f 80$
master cylinder 80
power steering resevoir 10$
Ebrake with leather handle 40$
wiper motor 30$
Gli rear view Mirrors 30$
esp,rear defroster & healdights control 10 each
amp with case 40$
cluster with 177,000 miles 80
dash surround pieces
ebrake handle 30$
relays 20 each
vents 10 each
rear view mirror 30
battery tray 20$
pop out cupholder 30$
6 speed shifter boot and knob 30
driver side mirror control with door latch 20 each
24 valve vr6 ecu 100
buttons 10$ each
vr6 engine cover 12 valve
tailights 60 set
hood hinges 20$ set
window motor 20 each
battery cover 20 $
fuse cover 10 $
6 speed starter
mirror
radio,hvac controls,radio cage and pop out cup holder
Monsoon Double Din radio
if interested in parts you dont see listed
contact us at (646) 752-0100
#4
Aluminum door handles?
Sent from my DROID BIONIC using Tapatalk 2
#5
#7
#9
do you have the front left ABS wheel speed sensor wire available? if so, how much shipped to 56636?
#10
#17
driver side mirror controller, how much shipped to 83647?
#19
my pillars are black on my 04.6 if interested look at that thread
#22
Longshot. Got the headliner for this or any other MKIV jetta?
#23
#26
I'll take the ESP button and headlight switch pm me please for pricing to 98372
#28
Do you still have the shift boot/knob?
#29
#32
How much you looking for the pop out in-dash coaster?
#33
#34
do you have just the mirror caps? looking for just the passenger but will buy both if needed.
#35
