Results 1 to 12 of 12
Thread: Adjustable cam gears??
  1. 05-02-2012 10:55 PM #1
    I plan on getting 268 cams + other mods. Found adjustable cam gears on renoks.com. I dont know if this companys reliable or not, but i know theres alot you can do with adjustable cams on american cars and others. Was wondering if they do anything on the r32 motor and if so what should they be adjusted to for maximum gains?
  2. Member newcreation's Avatar
    Nov 23rd, 2003
    HBG, PA
    04 R32
    05-02-2012 11:03 PM #2
    They adjust with oil pressure due to vvt already .
    -JAMES-
    Daily Drive /Beaten/Built /UM Turbo R - VR NATION
  3. 05-03-2012 10:42 AM #3
    So thats all they do..and vvt??
  4. 05-04-2012 09:23 PM #4
    Anyonee elseee???
  5. Member yocoop's Avatar
    Feb 17th, 2007
    SEPA
    2004 RS R32, 2003 VW GTI 20th Anniversary
    05-04-2012 10:09 PM #5
    Quote Originally Posted by mikegioia17 View Post
    variable valve timing
  6. Member TheRedMouse's Avatar
    Jan 21st, 2006
    L O A, IL.
    4-Motion mk4, and a mk2 GLI
    05-05-2012 10:42 AM #6
    The cam gears are adjustable from the factory.
    variable valve timing = google it
    I <3 C.O.R.T.
    LOA Member: #16
  7. 05-05-2012 12:22 PM #7
    I wasnt asking how they worked i was asking if anyone has advanced or retarded the timing with sucessful results?
  8. Member blinkinbanana's Avatar
    Jul 14th, 2000
    Long Pond PA
    '04 R, '10 Jetta TDI
    05-05-2012 12:27 PM #8
    I think the reason you aren't getting the answer you are looking for is because for the most part the answer is NO due to the VVT.
    IATSE Local 52
    AASI lvl 3
    USASA lvl 1
  9. 05-05-2012 03:38 PM #9
    Quote Originally Posted by blinkinbanana View Post
    Would make sense
  10. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    05-05-2012 06:55 PM #10
    Some of the tuners change the cam timing. I know Atwood does.
    -Josh
  11. Member newcreation's Avatar
    Nov 23rd, 2003
    HBG, PA
    04 R32
    05-05-2012 09:14 PM #11
    Quote Originally Posted by PowerDubs View Post
    Yes using the oems he was talking about after market ones. like we did on the old 8v
    -JAMES-
  12. 05-06-2012 01:49 AM #12
    What they said^^^^
