Results 1 to 5 of 5
Thread: Where to get solid lifters for less than almost $22.00 a peice?
  1. Member Digimon2's Avatar
    Jan 11th, 2011
    pnw
    85 GLI
    05-02-2012 11:25 PM #1
    I was wondering if anyone could point me in the right direction of somewhere that sells solid lifters for less than $21.57 each, which is the cheapest I know of from the handful of sites I usually shop at. I'm not looking to cheap out on quality necessarily, just looking to save a few bucks because this stuff is starting to add up! ..big surprise
    TIA
  2. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    05-04-2012 12:18 AM #2
    I have been running solid lifter heads since 1983 and have never had to replace one. Never seen one fail or wear out.
    FS:Sunroof Deflector
  3. Member Digimon2's Avatar
    Jan 11th, 2011
    pnw
    85 GLI
    05-04-2012 12:30 AM #3
    So if I am putting a cam in I should re-use the ones that are in it? ..because everywhere I have read on that subject highly suggests that new followers be put in when installing a cam.
  4. Member Digimon2's Avatar
    Jan 11th, 2011
    pnw
    85 GLI
    05-04-2012 12:44 AM #4
    ..or can anyone give me a part # on which diesel lifters that can be used a lighter replacement?
  5. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    05-04-2012 01:40 AM #5
    Solid lifters use a "puck" for adjustment, and that is the part that actually makes contact with the cam.
    You are thinking of the hydro lifters, to replace with a new cam.
