Results 1 to 5 of 5
Thread: please help project for manual trans class
  1. Junior Member joehoff2213's Avatar
    Aug 16th, 2011
    lancaster pa
    02 a4 3.0 98 cbr 600
    05-03-2012 12:35 AM #1
    hi guys i have to write a report about my car for my manual trans class , so i need so info if u all could b so kind to help out .
    firt things first , i an 02 audi A4 3.0 v6 quattro with the 6 - speed manual trans .
    here is a list of the things i need to know .
    type of driveshafts
    type of drive axle
    TYPE OF CLUTCH SYSTEM
    type of clutch actuation linkage
    type of preasure plate
    types of dampenning
    TYPE OF SHIFT MECHANISM
    location in vehicle
    type of linkage system
    lacation of shifter mechanism on transmission or transaxle
    OVERALL RATIOS FOR EACH SYSTEM
    1 transmission
    overall gear ratio
    drive axel ratio
    overall vehicle ratio
    2 transaxle
    each gear ratio
    final drive ratio
    DISCRIPTION OF THE POWER FOR EACH SECTION
    cluth
    transmission or trans axle power flow for each gear
    transfer case for each range
    drive shaft
    drive axles
    I will be doing as much research as i can but i only have till 5/21/12 to have the the info typed up in report form and handed in so any help i can get would be great
    P.S the list is straight from the rubric so anything not applicable to my car just ignore and if u need any more info on my car just ask please and i appreciate all the help
  2. Junior Member joehoff2213's Avatar
    Aug 16th, 2011
    lancaster pa
    05-07-2012 10:09 PM #2
    is there anybody that can help me with this
    Nov 20th, 2010
    Guelph Ontario, Canada
    2004 Audi B6 1.8t Quattro
    05-08-2012 07:59 AM #3
    I believe this is your school project. Not ours.
    Quote Originally Posted by doug808 View Post
    What a dick! not in over my head, just not sure what to do is all.
    VCDS and Vag Tacho in Guelph, if anyone needs to use it. PM me.
  4. Junior Member joehoff2213's Avatar
    Aug 16th, 2011
    lancaster pa
    05-09-2012 02:41 AM #4
    if u cant help then dont b a dick
  5. Member 98blueb5's Avatar
    May 11th, 2008
    NH
    B6 A4 3.0
    05-21-2012 12:39 PM #5
    I think what he was trying to say is that you should be looking it up yourself; im sure its accessible online.. Im sure you will learn more doing it that way.. Good luck with the paper!
