Results 1 to 7 of 7
Thread: G60 temp gauge not working properly on 2 clusters ?
  1. 05-03-2012 03:55 AM #1
    Hello.
    I recently bought a Golf Mk2 with a G60 engine in it and I have a few small problems among which this strange one with the temp gauge.
    The temperature gauge will never go more than 1/4 of the temperature scale.
    First I thought it is my gauge in the cluster and I replaced the whole cluster with a Figifiz cluster.
    On the new cluster the same, the temp will go at max 25% of the scale.
    Then I replaced the sensors, both the black and blue one ... same thing.
    I took 2 other sensors from another engine .. still the same issue.
    Isn't the black sensor the one that sends the temp reading to the cluster ?
    So with 2 sets of sensors changed, two different clusters (one analog and one digital) and the damn temp gauge still not working properly what else could be wrong ?
    Can be a relay ?
    Can be a bad earth somewhere ?
    Any other known issues ?
    Thank you in advance.
  2. Member mattrip's Avatar
    Sep 5th, 2005
    USA
    92' Corrado
    05-03-2012 11:33 AM #2
    The black sensor is the one for the temp gauge. I would start with checking the wiring with an ohm meter. This sensor/gauge work of of resistance.
    "A sudden provocation does not make me an ill-tempered man. It shows what an ill-tempered man I am."
  3. 05-03-2012 12:02 PM #3
    I changed this sensors 2 times ... and with 2 different clusters ... no change.
    Can I suspect wiring somewhere ?
    Where does the wire go from the sensor ? Directly to the fuse box or trough a relay first ?
  4. Member mattrip's Avatar
    Sep 5th, 2005
    USA
    92' Corrado
    05-03-2012 03:38 PM #4
    Would need to consult the manual to trace the wiring thru the firewall. Doubt there is a relay involved as the sensors and the gauge work off of resistance.
  5. 05-03-2012 06:23 PM #5
    Just came into my mind : As it did this with 2 clustrers and the Digifiz, and I changed 2 sets of sensors .... maybe my engine is indeed runing cold all the time ???
  6. 05-05-2012 10:06 AM #6
    mine does the same thing. i dare you too drain your coolant then run it and see what happens
    PS, that was a joke. Don't do that.
    But yeah, its fine. the temp goes higher in my car when i sit in traffic for a while, but yeah, its normal.
    1990 Jetta coupe. G60 swap.
  7. 05-10-2012 02:00 PM #7
    Changed the thermostat and the temperature problem is solved now, temperature is within the parameters.
