Hi There,
I have mk4 tdi - 1999 which has a starting problem.
The engine turns over and fires almost emmidiately but does'nt run. I can go through this process many times and eventually it will start. Once it starts it runs as normal and when the engine is at running temp it starts as you would expect it to. Any ideas?
