Results 1 to 14 of 14
Thread: 304 code cylinder misfires
  1. Member euro2envy's Avatar
    Jan 9th, 2010
    SoMD
    Low n Slow B6
    05-03-2012 09:42 AM #1
    Scanned and code 304 cylinder misfires. Mods are APR stg 2, catless downpipe, cat back exhaust, forge intake, oem dv, coil packs were replaced under recall. can this by to not changing the spark plugs or the diverter valve?? Car drives perfectly fine however.
  2. Member low_passat's Avatar
    Sep 11th, 2010
    Goodyear, AZ
    05-03-2012 10:38 AM #2
    This is the order I'd start...
    Spark plug>Coils>clean the valves
    Are you experiencing rough cold starts? That's usually a sign it's time to clean the valves.
    Are you really stage 2 with original diaphragm diverter valve? That's a miracle in itself...
    2007 Candy White/Black Passat 2.0T Wolfsburg Edition| APR Stage 2+ | APR HPFP | Forge WINtake | S3 Intercooler | B&B 3" Turbo-Back Exhaust | Dogbone Insert | FK Silverline+ Coilovers | Front Lip Spoiler/Hi-Def Sideskirts | Votex Trunk Lip Spoiler | R-Line Fog Grilles | Clear Corners | HID Kit - low beams & fogs | RCD-510 | Podi Boost gauge | R-Line Pedals | GTI Steering Wheel |
  3. Member euro2envy's Avatar
    Jan 9th, 2010
    SoMD
    Low n Slow B6
    05-03-2012 11:09 AM #3
    yea im really stg 2 with original dv waiting on the awe dv to be back in stock seems everyone jumped on it... any special spark plugs to buy or just from the dealer??
  4. Member Weelildubb2.0t's Avatar
    Apr 19th, 2007
    The Sticks, CT
    B6 Passat 2.0 Turbo
    05-03-2012 11:59 AM #4
    How many miles on the car?
    Oct 7th, 2011
    Minnesota
    2008 Passat B6 6MT FSI
    05-03-2012 12:03 PM #5
    I had multiple misfires on my stage 1+ tune. Look into your PCV. Thats what it turned out being on mine. I had gone back to the OEM one before a dealer visit, and never put on the BSH revamp after the visit. I threw misfire codes, and rough idle at start. That may very well be your problem, I didnt see any revamp in your mods list . They fail commonly under increased boost from what I have read/experienced.
    Good luck on the solution
    2008 United Gray B6 Passat 2.0T FSI 6 M/T
    Engine: APR Stage 2+ [] USP TestPipe | APR HPFP | AWE DV | BSH PCV Kit | CTS Turbo Intake | AutoTech CatBack
    Exterior: 034 MotorSports Dogbone Insert | ABT style front lip | VMR V710 19x8.5
    Interior: Climate Knobs | Pioneer DVD unit | Kenwood 9104D amps | Kicker L7s
  6. Member euro2envy's Avatar
    Jan 9th, 2010
    SoMD
    Low n Slow B6
    05-03-2012 12:28 PM #6
    89,000
  7. Member euro2envy's Avatar
    Jan 9th, 2010
    SoMD
    Low n Slow B6
    05-03-2012 02:20 PM #7
    UPDATE: along with code 304 there is an oil leak also.
  8. Member nodashi's Avatar
    Mar 20th, 2012
    Whidbey Island, WA
    2006 FSI 2.0t Passat
    05-03-2012 04:27 PM #8
    how does one clean the valves? Also what spark plugs should i buy?
  9. Member Bill6211789's Avatar
    Dec 11th, 2009
    Clifton Park, NY
    2006 VW BT Passat
    05-03-2012 04:55 PM #9
    what motor do you have?
    If your an FSI i would say DV is prob blown, but tht may not be ur issue. When did u last have ur spark plugs changed? and if there has been no valve cleaning thennn ur at tht point too.
    this is a car at 60k
    Unitronic Stage III w/ PT5558BB Turbo (What a difference UNI is from APR!!)Unitronic.ca,HPFP Upgrade Stage 1 pump, 3in.TBE, BSH throttle pipe/27mm RSB/Endlinks , Forge 007 DV , RalcoRC SS, 42Draft Design CNC Shifter bushings, N2MB WOT box, BFI stage 2 motor/tranny mounts, 034 Dogbone, Koni FSD shocks, Neuspeed springs/25mm FSB, Whiteline Anti-lift kit/Front control arm bushings, 18x8.5 VMR VB3s, JBL stereo, CTS Turbo 2.0t FSI Big turbo kit!
  10. Member nodashi's Avatar
    Mar 20th, 2012
    Whidbey Island, WA
    05-03-2012 05:15 PM #10
    How do i clean my valves? Also how much would it cost for someone to clean them for me?
  11. Member Bill6211789's Avatar
    Dec 11th, 2009
    Clifton Park, NY
    2006 VW BT Passat
    05-03-2012 05:19 PM #11
    Quote Originally Posted by nodashi View Post
    http://forums.vwvortex.com/showthread.php?4611119
    to have a shop do it properly will cost a decent amount i think easily above 500$, unless they walnut blast them which is much quicker
  12. Member euro2envy's Avatar
    Jan 9th, 2010
    SoMD
    Low n Slow B6
    05-03-2012 05:30 PM #12
    Quote Originally Posted by Bill6211789 View Post
    FSI motor, i just ordered AWE dv.. anything else i should be checking for.. also valves and spark plugs have never been changed... oil leak another issue i guess?
  13. Member euro2envy's Avatar
    Jan 9th, 2010
    SoMD
    Low n Slow B6
    05-07-2012 04:55 PM #13
    so when running tune the DV tend to blow and what else should be replaced?
  14. Member
    Oct 7th, 2011
    Minnesota
    05-07-2012 05:27 PM #14
    Quote Originally Posted by euro2envy View Post
    as I said before, and I have experienced this problem first hand with just a stage 1 APR 91 octane tune, the PVC tends to blow out. A good solution to this problem is the BSH PCV revamp kit.
    This is one of the most commonly used kits (atleast what I have seen, and what I purchased)
    http://uspmotorsports.com/product_in...roducts_id=770
    The intake manifold cap also makes a great mounting point for your AWE diverter valve (that is where I tapped mine) and a boost gauge should you decide to purchase one (the block-off has two tap points).
    I have been running my car with this mod on for a good 4 or more months, and have been nothing but pleased with it.
