Hi, With pain in my heart I have to sell part of my project...
Up for sale is a Black Case MegaSquirt I PCB 2.2v with Spark-n-Extra:
Firmware 029y4.
It has been modified with Ottawa's pin modification to be able to run this using either the 7-pin ICM or the 3-pin Voltage Regulators in VW's. In addition it lets you use the Idle Valve so as to not lose the A/C nor have ridiculous RPM drops.
http://www.ottawa-vdubbing.com...15948
It has a 4-BAR Map sensor (a must for highly modified or turbo applications) as to have the 12x12 fuel map or if you wish the 16x16 (400Kpa) which further improves the tuning ability of the A/F.
I have the harness completely assembled and labeled, with the only need to cut and join the plugs from your car and ground what need to be grounded. Only thing that it needs to install is a throttle with TPS and either an ICM or a 3-pin 16v voltage regulator.
Comes with a GM IAT sensor and uses the stock Bosch sensor for CLT (coolant temperature) the values are already set into the computer.
It has a base spark-fuel map installed.
Will also come with a serial to usb adapter and cable that works perfect with the tuning software (can use a modern laptop) and I'll include the software, the base map, both wiring diagrams for either an ICM or a 3-pin VR.
Selling everything for $450 shipped,
Contact me with any questions, and yes I accept paypal
