Mine's the same way. I'm in for suggestions too.
Took Nimbus out last night for a shake-down cruise (weather was waaaay too nice to stay home) and other than a bit of smoking on trailing throttle (valve guide seals??), I noticed that the clutch engages when the pedal is almost at the top of the stroke. I'd like it to operate a little closer to the floor, as a personal preference. Is there a quick adjustment that can be done?
DW
It's 106 miles to Chicago, we got a full tank of gas, half a pack of cigarettes, it's dark... and we're wearing sunglasses.
-Hit it.
RooflessVW
And mine is just the opposite, too low. Someone let us in on the adjustment secret.![]()
Tuco, there are two kinds of people in this world...the ones with loaded guns, and the ones who dig. You dig. - Eastwood
93 Cabby09 Jetta TDI 93 Corrado S/C
Assuming you're talking about the standard manual tranny clutch cable.....
Look where the cable attaches to the tranny.
You will see a nut on a threaded rod, built into the clutch cable.
You will see a round cable adjuster sitting on a tranny plate, with rubber under it.
Loosen the nut..i think its a 14mm.
Spin the(generally white) adjuster to screw IN the threaded rod into the cable housing.
This loosens the cable.
Turning the adjuster so the threaded rod comes OUT of the cable housing tightens the cable.
It doesn't take much.
See if the pedal is to your liking. Adjust more if not enough.
When you're happy, re-tighten the nut on the threaded rod so things don't move on their own.
Enjoy your ride.
If I loosen my cable any more, I'll be out of spec on freeplay. Won't my clutch pedal be all floppy, but still engage/disengage right at the top?
-Hit it.
RooflessVW
All this adjustment does is give more or less freeplay(distance the pedal can move without actually pulling tight on the clutch) into the pedal. If your clutch itself is worn so far down that you can't adjust the cable for happiness and still have the clutch work right...well....theres only so much a cable can do.
On the other hand, if you feel clutch pressure as soon as you press the pedal, this will allow you to move that pressure point more to the floor of the car..or vice versa. Pedal will have more/less room to move before you feel serious pressure.
I will also warn about having the cable too loose. I've fixed a cable for a friend, where it was so loose, it popped off the clutch pedal hook inside the car. Not a good thing to have happen.
I'll leave it within specs then... I would just chalk it up to my clutch, pp, and flywheel combination, but I know people with stock stuff that acts the same way. Maybe different brands are what cause the differences?
-Hit it.
RooflessVW
Is this a "from the top" or "from the bottom" adjustment?
DW
it just allows slack in the cable...exactly like a bicycle hand brake adjuster works. Where that slack goes is usually on the pedal end.
The adjuster is on the tranny end of the cable...not the pedal end.
no no no guys......you cant adjust the cable like that....
the manual adjust cables need to be tight on the throw out release arm or else you can break the cable or the cable will come of the release arm
the idea behind this is that the pedal SHOULD be tight at the top and not floppy
however if your pedal and cable are tight but the clutch engages at the floor then that means your friction plate is worn out or your flywheel is worn out
its not about making it comfortable for you, its about doing it according to the correct spec
#12
From BrokeVw.coms site..... http://brokevw.com/releasearm.html
