Results 1 to 3 of 3
Thread: fuel filter
  1. Member g60301's Avatar
    Aug 4th, 2011
    Maryland
    90' Corrado m62
    05-03-2012 01:55 PM #1
    I've done a little research already but I feel I'm getting horrible gas mileage in my g60. I know it wont be the same as stock considering I change the injectors /fpr. Main question IA where can I find the best price for a fuel filter and is OK to run a aftermarket one or should I stay away from aftermarket? I was thinking of calling parts authority. And I've red the blue temp sensor could mess with the mileage a little
    Jan 11th, 2010
    Federal Way
    91 GLI G60, 86 Golf GL
    05-09-2012 07:35 PM #2
    If the blue temp sensor is disconnected you will get horrid mpg, and you'd notice a huge performance difference. It would cut power too, if the connection was intermittent.
    I wouldn't be concerned about the fuel filter unless it is clogged, which you can flow test. But order one from germanautoparts.com under Corrado.
    Check for boost leaks! 02 Sensor, if you have a aftermarket chip it could be also giving too much fuel - especially if you're running a M62. A lot of those chips have fuel curves specifically meant for the G-lader because it builds boost as it goes through the rpm's.
    I get a steady 21mpg city w/s4 ported g lader s4 chip, 02 sensor delete.
  3. Member g60301's Avatar
    Aug 4th, 2011
    Maryland
    90' Corrado m62
    05-11-2012 01:11 PM #3
    Quote Originally Posted by KirinC View Post
    BBM recommended me a stg4 chip so how ever the fuel curve on that is beyond me. Prob should get a custom mapped sns chip.
