Ok so this is my first post ever and 3 days ago was the first time I have ever taken any interest in a water cooled vw motor. I am a rock crawler guy and a desert racer so 8v vw motor isn't somthing that's common in my world. But I have come accross a 1.8 8v motor for sale with all the adapters and wirring to bolt into my samurai based rock buggy. I will list the spec sheet on the motor and I would like some oppions on the good or bad parts used to build it and how easy or hard it will be to dial in and keep in tune. Also if you guys could give me estimated hp and rpm range I would really appreceaite it.
1.8 8v german cast block
Forged crank
Forged rods
Lightend flywheel
Lightend cam gears
168 grind cam solid lifters big valves
10.5 to 1 with crommolly rings
A2 throtle body and intake
Cis injection
Duaul outlet exhaust manifold
Thanks in advance if I left out needed info or I sound stupid keep in mind this is the first time the words vw have left my mouth.
Wikkipedia said these motors are 105hp stock so seems like there should be more than a 10 horse gain. The motor is supposed to be pretty fresh seller claims it only has 2 seasons of rock crawling on it. Price is 500 plus 300 to ship it. But the adapters to my bell housing motor mounts and all plumbing and wiring are included.
120 hp is pretty dissapointing news seller claims 170 and I'm not sure that 120 would be worth the effort. And since its 10.5 to 1 boost is out of the question
Rereading things and seeing it's SOLID lifter, that's fine. Just wondering where he's getting these numbers. When he built it was anything punched out? Any other headwork besides the mild cam?
He Says port matched and bigger valves installed guy doesn't. Seem to know exact details I think he had the motor built and is just reading off the build sheet he claims 10.5 to 1 and 30 over. The guy seems really honest and has been super friendly to deal with but I wonder if he is a lil missimformed. he said he was told 170 at the crank. Thanks for the responseand keep it comming.
its still not 170hp tho.. not a possible chance.. im leaning towards ~120hp, like everyone else..
10.5:1 compression is just stock compression, with a slightly decked head.. thats not enough to make 170hp.
that engine would need to be REALLY BUILT.. like not streetable, and it would need more than a 268* cam..
a small cam, slight bump in compression, dual outlet manifold, and over size valves are not going to boost the power by 60hp.. sorry, the guy had smoke blown up his @$$.
if it were a modified 1.8L 16v engine, then the 170hp would be MORE believable, but still a LONG shot..
No need to be sorry thanks for the info couple more quick questions any idea what the torque would be? How hard is the cis to deal with tune and keep tuned? And if 10.5 is close to stock compersion could I throw a lil boost at it with out droping compersion?
10.5:1 is too high for boost, unless you had megasquirt, and it was tuned PERFECT for boost and compression.. CIS really doesnt EASILY lend its self to boost, unless its basic, or lambda.
there were 8.5:1 compression engines, and 10:1 compression engines. the 8.5:1 compression engine lends its self to boost quite nicely, where as the 10:1 compression is DEFINITELY more picky about fuel mix, and timing..
torque will probably be around the same as HP, with how the engine is built..
CIS really isnt hard to tune at all, or set up.. you shouldnt need to tune it. as long as you set it up as it should be, it should still be factory tuned.. but if you DO feel the need to tune it, its not hard, and once you tune it, you should never need to tune it again, unless you radically modify the engine..
So know boost with out swaping pistons and engine managment. Where abouts the power curve and the redline gonna be with this cam? I searched but couldn't find much info on it. And 120 hp is terrible my rig weighs about1800lbs and with my gearing combo I hit about 7500 rpm at 70mph in 5th
By 168 cam, maybe you mean 268 cam? If it has a 268 cam, that's a cam for a hydro head, not a solid lifter head.
Based on the specs, I'd say you're looking at about 115hp at the crank. But it should be a nice, reliable (if it was assembled properly), flexible motor.
I have 1.7 to 1 hi range and 5.12s in the diffs with 31s I know my way through every part of a sami a yota and 4x4 chevys its vw that I'm clueless about my rig is not really a sami more a sami based buggy built for dual purpose crawlin and runing wide open across the desert. The trannys are super weak but I have three and yet to brake one. My current motor setup probaly has about 80hp at the crank.
I belong to a couple sami forums and pirate 4x4 I have built a few samis into hard core crawlers my stuff get dented beat and destroyed then rebuilt stronger. If I do install this motor then I will keep you posted for sure I have a lot to learn about these motors how to build them and how to tune them. Thanks again for the input and info
This thread kind of caught my attention... I also agree that that motor is not pushing anywhere near 170hp. Maybe ~120 like previously stated.
I will also add that tuning the CIS system is very easy to tune. If it's a CIS-E engine, you basically need a multimeter that can read milliamps, tuning harness, and a long 3mm allen bit. You don't really even "tune" it, you just tweak it to have the correct air-fuel ratio so that your not running too rich or too lean.
Keep us updated on the swap if you decide to do it and DON"T COME BACK WITHOUT PICS!!! Just kidding.... but seriously, it's cool to see a different swap going on here every once in a while.
Related Threads
Ask a question
Ask a question
VW Vortex - Volkswagen Forum
84.4M posts
1.5M members
Since 2001
