VWVortex.com - My GTI rusty rebuild progress
    Page 1 of 6 12345 ... LastLast
    Results 1 to 25 of 145
    Thread: My GTI rusty rebuild progress
    1. Member heerschap's Avatar
      Mar 18th, 2009
      Woodstock
      97 Ginster DE/95 Jetta GLX (RIP)
      05-03-2012 04:44 PM #1
      This is my rusty rebuild project for the summer and this thread is about my progress . Its my first time, so go easy. Any advice or constructive criticism is welcome.
      its a 97 GTI Drivers Edition vr6 with 75,000 km. paid $1500 and probably spent like $3000 on it over the 3 years ive had it now. its mostly been in storage and engine runs great. I just did the timing chains and clutch back in the winter. I now need to fix some important rusty spots ive found and this is going to be much easier with the engine out, plus I need to clean up the block and replace some parts here and there. I also have lots of rusty pictures of areas to be fixed in my sig, but for now one section at a time.
      my progress so far
      pop rivets and construction adhesive
      its actually quite strong though
      next step is sub frame comin out.
    2. 05-03-2012 04:44 PM #2
      Looks great
      Did you know that it's not pronounced Em Kay ? ALL OF THE CAR LOUNGE WILL BE HAPPY TO LET YOU KNOW THAT. SERIOUSLY. IT STANDS FOR MARK. DID YOU KNOW THAT? BEFORE THAT A1,A2, A3, ETC WAS USED. LIVE UP TO TCL STANDARDS BEFORE YOU GET ON MY ASS. THAT'S DISGUSTING.
      Example of TCL's standards
    3. Member WakusPakus's Avatar
      Feb 13th, 2012
      2012 Honda Accord, 97 Bayliner, Yamaha Whorrior
      05-03-2012 04:46 PM #3
      your car is one giant red X
      Quote Originally Posted by nicoli View Post
      Wow... Who says Hondas have no torque?
      CRV: cranial removal vehicle
    4. Member MYGTI_MA's Avatar
      May 3rd, 2010
      North of Boston
      '97 GTI 2.0T (v2.0) // '94 Golf LC5P // '83 Rabbit Diesel
      05-03-2012 05:44 PM #4
      for a DE car
    5. 05-03-2012 05:55 PM #5
      How is it so rusty with that low of km?? I had to convert it...46,000 miles. Holy cow. I thought mine was bad, but I've got 178,000 mi / 287,000 km.
      Quote Originally Posted by mhjett View Post
      I'm convinced you commuted through a salt mine.
      Quote Originally Posted by Mk3_Addicted View Post
      Bariman82 is the king of rust patching...He is the guy you want to talk to.
      My take on fixing a rotten mk3.
    6. Member heerschap's Avatar
      Mar 18th, 2009
      Woodstock
      05-03-2012 06:03 PM #6
      Quote Originally Posted by Bariman82 View Post
      all it takes is driving a couple salty winters up north here, then it sits outside and rust?.
    7. Member masdubate's Avatar
      Apr 25th, 2010
      allentown pa
      97 vr jetta, 96 2slow jetta
      05-03-2012 06:12 PM #7
      My tower was the same way check my signature it might help
    8. Member heerschap's Avatar
      Mar 18th, 2009
      Woodstock
      05-03-2012 06:24 PM #8
      ya nice work ive been following both your guys threads. it really motivates me too!
    9. Member heerschap's Avatar
      Mar 18th, 2009
      Woodstock
      05-07-2012 06:58 PM #9
      update:
      subframe and fenders are off
      now i need a plan of attack for this strut tower
      thinking of just cutting the rot out and welding a patch in???
      top seam of strut tower dont look to bad
      drivers side tower looks to be ok.
    10. Junior Member Shawn Biggs's Avatar
      Feb 25th, 2012
      Burton,MI
      1996 Golf GTI VR6
      05-07-2012 07:13 PM #10
      Exterior looks clean though,a lot more than mine being a Michigan car,of course we all know how much rust is hidden,gl on the progress
    11. Member heerschap's Avatar
      Mar 18th, 2009
      Woodstock
      05-07-2012 07:56 PM #11
      hey thanks for all nice comments guys
      so anyone know if I could use a welder like this for solid weld?
      http://www.tscstores.com/CENTURY-AC1...ER-P15182.aspx
      even if I just do all tac welds for the patch then epoxy type filler the rest in, should be just as strong, if not stronger than a solid weld.?
    12. Member heerschap's Avatar
      Mar 18th, 2009
      Woodstock
      05-08-2012 07:15 PM #12
      some anti rust stuff I will be using.
      got some cutting and wire brushing done.
      Im doing half the tower at a time, this way it dont bend or move out of position.
      im thinking of tac welding the patches in, then lay down a bead of JB weld over the seams afterwards.
    13. Member Dan821821's Avatar
      May 23rd, 2011
      NY
      1998 Gti VR6
      05-08-2012 07:18 PM #13
      i would stay away from stick welding thin metal. And you will probably have to order ur electrodes online, 1/16 is very small and uncommon. But if you have some experience im sure its duable though ive never ran anything at 15 amps before. Also be sure to follow your duty cycle, that 20% is out of ten minutes, u can tack 2 mins worth in a 10min period or risk burning out ur welder.
      Imo id go with hardwire(mig) and argon75/25Co2 gas(i prefer esab wire).
      I know its about 3x the price but itll work for other projects down the line and do what u want with less fuss.
      http://weldingsupplyusa.com/index.ph...1#.T6mbc1Ks8cU
    14. Member heerschap's Avatar
      Mar 18th, 2009
      Woodstock
      05-08-2012 07:51 PM #14
      I can rent a mig for $40.00/day at the local rental place, but I need to buy the gas myself. not sure if the bottle comes with or not though?. thanks for the advice too. I dont have much experience with stick welding, I use to weld piping for greenhouse boilers like 10 years ago, but thats much thicker.
    15. Junior Member
      May 8th, 2012
      Remsen, NY
      97 Jetta GLX, 95 Jetta City (daily), 85 Scirocco, 96 Jetta GL (daily project), 94 Jetta GL (Parts)
      05-08-2012 07:57 PM #15
      From experience MIG welding rusty sheet metal, that's what you want, with the .023 wire, not .030, and gas (MIG) not flux core. And I would tac in place and then run short beads with just enough heat to get a smooth weld then letting the thing cool between or it will warp everything. Not sure if JB Weld will give you the strength you need.
    16. Member heerschap's Avatar
      Mar 18th, 2009
      Woodstock
      05-08-2012 08:23 PM #16
      ya I will go the mig route, although jb weld is apparently stronger than regular welds
      Properties (psi)
      Tensile Strength:
      3960,
      Adhesion:
      1800
      Flex Strength:
      7320
      Tensile Lap Shear:
      1040
      Shrinkage:
      0.0%
      Resistant to:
      500° F
    17. Member OMGitsKYLE!'s Avatar
      Apr 10th, 2009
      Boston, Ma
      05 PG GLI (sold), 96 Burgundy bagged and blown 2.0 Jetta (Sold) , MKVI Candy White Golf (Daily)
      05-08-2012 09:01 PM #17
      ohh yah im watchin this 1
      VolkShore Co-Founder
      www.VolkShore.net
      on instagram @krbelch
    18. Member heerschap's Avatar
      Mar 18th, 2009
      Woodstock
      05-14-2012 07:42 PM #18
      got a little work done
      drilled out spot welds
      removed them with hammer n chizzle
      cleaned it up abit
      the other side which is almost rotted through.
      now for the outside brackets
      cleaned up
      will be cutting and grinding some of the really bad spots out next...
    19. 05-15-2012 01:59 AM #19
      I had to do the same with my brackets. I honestly cannot believe how rusty that car is for the km. Given that shock tower, I hope you pull this repair off.
    20. Member heerschap's Avatar
      Mar 18th, 2009
      Woodstock
      05-15-2012 10:08 AM #20
      I know right, I was told this car sat in a moist grassy field, plus our humid summers for many years rusting. anyway I hope I can too my brother is a welder by trade and he said he would help me weld it up, providing I get a good mig welder. I am taking my time and make sure its done right and this car will never see another winter anyway.
    21. Member heerschap's Avatar
      Mar 18th, 2009
      Woodstock
      05-16-2012 08:36 PM #21
      more surgery
      bought a used mig welder in the local classifieds for $320 included 3 full bottles of gas, couple spools of wire, helmet and a cart.
      let the games begin
    22. Member heerschap's Avatar
      Mar 18th, 2009
      Woodstock
      05-19-2012 12:03 PM #22
      fabed up some patches
      took care of some hard to get at pitted rust areas
      ready for some welding this weekend
    23. 05-19-2012 07:43 PM #23
      Good job saving it **** rust.
      This is the only part I dislike. Looks terrible. Did you seek a donor tower from any junkyards? I'm sure somebody on here can source one for you.
      PVW 5/11 Held It Down
      mk2 1.8t ~ mk3 vr6t ~ mk3 vr6 ~ 7p5 3.6exec
    24. Member Vdubztar03's Avatar
      Mar 30th, 2011
      pitssfield mass
      03 gti
      05-19-2012 07:54 PM #24
      Good start are u going to be shaving your bay ??
      pittsfields downtown dubs
    25. Member
      Dec 30th, 2007
      Central VA
      08' A3 S-Line 3.2L / 04' TR V1 Supercharged .:R32 /04' .:R32 Swapped GLI
      05-21-2012 04:27 PM #25
      lookin good man ... goodluck with it ... my hatch was pretty rusty so i just bought a new eurohatch @ sowo this weekend
      _R-1-3-5 _
      _└-┼-┼-┤_+AWD_=_WIN!!
      -__2-4-6____
