Results 1 to 6 of 6
Thread: My 98 Cabrio wont start!
  1. 05-03-2012 03:53 PM #1
    I drove it to work yesterday and it was fine but when I went to leave it took 3 or 4 times turning the key to get it to start. I drove across the street picked up some groceries and then when I came back out and tried to start it it did nothing. The lights and radio come on but its not turning over. Tried to jump the battery (which is brand new) and it did nothing. NEED HELP! Is it my starter??
  2. Member CajunSpike's Avatar
    Mar 11th, 2009
    New Orleans, LA
    91 Burgundy Etienne(2), 92 Green Carat, 99 Passat Sedan, 01 Passat Wagon
    05-03-2012 04:28 PM #2
    Starting to sound like maybe your ignition switch has a problem.
    turn the key to the on position, then try manually cranking the starter by connecting the solenoid wire with the battery wire, on the starter. if you're not sure how to do this, say so.
    if it starts by 'hotwiring the starter' but not with the key....i'd be buying a new electrical end of the key switch.
    i just got a cabrio myself..not an expert...yet.
  3. 05-03-2012 05:28 PM #3
    Thank you for the help! I definitely do not know how to do that though haha anyway you could be more specific about where the wires are located?? Ill try that
  4. Member CajunSpike's Avatar
    Mar 11th, 2009
    New Orleans, LA
    05-03-2012 05:35 PM #4
    the starter is on the front side of the transmission.
    A heavy wire goes from the positive side of the battery to the starter solenoid.
    A thin wire goes from the key switch to the solenoid.
    Another thick, short wire goes from the solenoid to the starter motor.
    Unplug the thin wire going to the solenoid.
    Grab a piece of wire about 3 feet long.
    touch one end of the wire to where that thin wire plugged into the solenoid.
    for a second or two, touch the other end of the wire to the positive side of the battery.
    it may make sparks, but if you do it right, the motor will spin over.
    this will confirm if the starter is good or bad.
    spins - good
    no spin = try again make sure you make good connection, or bad starter.
    Ask a friend for help if you can't follow this.
  5. Member Sanityana's Avatar
    Mar 4th, 2012
    Charlotte NC area
    1988 16v Scirocco 2012 GTI 2003 allroad 1990 Jetta GLI
    05-03-2012 08:37 PM #5
    Sounds like a bad key switch...
  6. Member tolusina's Avatar
    Oct 18th, 2004
    '95 Ranger, '74 Gitane Pista
    05-04-2012 01:26 AM #6
    Does this car have an auto or manual transmission?
    Quote Originally Posted by kamzcab86
    I hate reading: "But I bought this car for $500 and don't want to put another dime into it."
    _____________________(hey, it's VW AND it's electrical, what's not to fail?)
    neoBentley+
