Results 1 to 9 of 9
Thread: Interior Trim Removal
    Mar 3rd, 2010
    Montclair NJ
    2008 Passat "Komfort"
    05-03-2012 04:54 PM #1
    Hey guys i wanna remove all the gray pieces in my interior, i wanna spray them black, i have searched the forums as well as google, and i cant find anything detailing how to remove all the trims, such as the gray/silver trim around the radio, shifter, and the one that goes across the whole dashboard. If anyone could help, id be ever so pleased. thanks
    Dec 24th, 2011
    Belleair, Florida
    2006 Volkswagen Passat
    05-03-2012 10:15 PM #2
    Quote Originally Posted by MK4Laxer View Post
    I start at the little trays that pop out. If your not going to use a panel removal tool, just be careful. Nothing to worry about but don't pull too hard. If you open the trays, you can push up on the little faceplate. Then, push both back in and pull off the surround around the hazard button. Next, push against the trays and pull down on the radio surround. Don't unplug the passenger airbag harness unless battery is off. You can actually remove that entire light very easily if your careful. Pop up the top around the radio and run your hands down the side. After that's off, you should be able to get the one around the A/C controls off easily. After that, down to the coin holder/ashtray. Pull out the insert and un-screw the screws. I couldn't figure out how to remove the cover so I just took the entire thing out by unscrewing the screws. Unplug the power outlet/cigarette lighter. Before you take that out, you have to pop up the shifter surround. Just pull back on that w/ the coin holder door open. Then pop out the chrome shift bezel out and your done. Once again, don't unplug random harnesses unless battery is off. All of the upper dash trim pieces just pop off. Use a flat head screwdriver that you've wrapped in something (a towel, electrical tape, etc.) so it doesn't scratch the dash. If you want to remove the parts on the doors, they all just pry off. Easier than it sounds. Maybe 20 min job for all the pieces (to remove). I'd recommend vinyl wrapping over painting though; you can always peel vinyl off
    2006 Passat FSI 2.0T | Forge DV Spacer | 17" Monte Carlo Wheels | 10" Kicker sub in custom box | iPad Mini Dash installed as headunit | 5% Tint on sides, 30% on back window | Carbon fiber mirrors | Votex Roof Rack | Resonator Delete w/ Magnaflow tips | Badgeless grill | OEM Audi S6 LED DRLs | Lip spoiler
  3. Member indyb6's Avatar
    Sep 7th, 2011
    Indianapolis
    08 Passat FSI 2.0T
    05-03-2012 11:18 PM #3
    ^^^ Thank you for taking the time to write all this
  4. Member
    Dec 24th, 2011
    Belleair, Florida
    05-03-2012 11:23 PM #4
    Quote Originally Posted by indyb6 View Post
    No problemo
    Mar 3rd, 2012
    Lyndhurst, NJ
    2006 Passat 2.0T
    05-03-2012 11:51 PM #5
    Hey, could you send some pics of the vinyl wrapped interior?
  6. Member
    Dec 24th, 2011
    Belleair, Florida
    05-05-2012 11:42 PM #6
    Quote Originally Posted by Breakthecycle2 View Post
    and one with the old carbon fiber
  7. Junior Member VWejne's Avatar
    Sep 14th, 2009
    Slovakia
    3C 2.0 TDI sportline
    05-06-2012 04:23 AM #7
    I think this is better look of carbon . look of your ring how folia is there bad putted....
    Mar 3rd, 2010
    Montclair NJ
    05-12-2012 03:32 PM #8
    thanks guys! ye im using plasti-dip, it was just as easy to remove as vinyl
    Dec 24th, 2011
    Belleair, Florida
    05-12-2012 11:48 PM #9
    Quote Originally Posted by VWejne View Post
    Sorry my first time with vinyl didn't come out as you liked It was just an example, no need to talk trash about my work. It's pretty obvious that it's not perfect. And personally, since we're criticizing, I don't think that much silver carbon fiber looks good, does carbon fiber even come in silver?! I took mine off because it didn't look real at all, the finish and feel is off completely and re-did it in a brushed aluminum vinyl, which looks like brushed aluminum.
    I normally don't like arguing with people, but when opinions aren't asked for, it really irritates me when negative ones are given. This was to give the OP a view he was looking for, not for me to get thoughts on my trim.
