Results 1 to 4 of 4
Thread: Transmission shifting issues :(
  1. 05-03-2012 10:57 PM #1
    Ok, This week my '88 Fox started acting up a bit. I would shift into 4th and noticed that it didn't always engage. It felt like the shifter slipped in as normal, but no gear mesh. If I held the shifter back and let out on the clutch slowly, I could feel everything mesh and all was normal. Now, I just skip 4th and go from 3rd to 5th.
    Could this be just an adjustment, worn bushings? What is the best way to check it out?
    I have a parts Fox out back, the shifter was disconnected when I bought it, but I am pretty sure it is also a 5-speed. How do I identify the type of transmission? Where exactly are the markings at? I looked in my Bentley, but the picture wasn't real clear.
    Thanks,
    AK Chappy
  2. Member vwturbofox's Avatar
    Jul 31st, 2010
    washington,everett
    1989 vw fox gl turbo, Holset hy35 on meth:)new project 1968 bug
    05-04-2012 11:43 AM #2
    check the shift cluster that holds all the bushings is not loose i hade the same problem that little 13mm bolt and nut that holds it all together. it came lose and i kept missing gears and poping out of gears. i just lock tight mine never the problem again
  3. 05-05-2012 01:03 AM #3
    Thank you VwTurboFox, I checked that out tonight. The bolt was tight, but I think it is loose bushings. It appeared that the lever didn't push far enough forward, so I adjusted the linkage a hair on the spline shaft. I test drove it, at first it appeared to be better.
    Under a steady acceleration 3rd to 4th stayed in gear and shifted normally. Downshifting was a different story, 5th to 4th did not engage at all. Slow acceleration, 3rd to 4th did not grab either.
    I will search out the list of bushings on here and order them soon.
    Thank you again.
    AK Chappy
  4. Member vwturbofox's Avatar
    Jul 31st, 2010
    washington,everett
    05-07-2012 12:03 PM #4
    im not one to give bad news but do you think maybe your tranny is just really worn out.
    i have had a five speed before in my fox and the tranny was bad but still drivable.
    anyways good luck hope it's just a simple fix for you
