Results 1 to 8 of 8
Thread: Is it ok put a 10w-60 oil in a 1.8t
  1. n00b atarekvw's Avatar
    Feb 21st, 2011
    cairo, Egypt
    03 VW GOLF GTI
    05-04-2012 05:57 AM #1
    i have a 03 golf 1.8t AUM remapped and i live where temp is between 5 to 47 Celsius
    i've been using castrol edge 5w-40 (the 5w30 and the 0w30 is not available) but since i have had my car remapped the engineer there recommended a 10w-60 oil since its a fully synthetic racing oil and there are recommended for turbo charged engines
    i tryed the castrol edge sport 10w-60 and its working great (very smooth & quiet,etc... any way better than the 4w-40) and its the time to change it now and im looking to change to Liqui-Moly Synthoil Racetech GT1 10W-60 i heard that's even better
    BUT i've recently cheked the list of approve oils and i cant find a 10w-60 oil
    sooo ??????
    please help , thanks in advance
    Nov 10th, 2010
    mid hudson valley
    02 jetta wagon 1.8t, 03 passat 1.8,06 jetta 20t
    05-04-2012 08:05 AM #2
    unless you have an oil heater you probably should stay away from something that heavy. with a turbo it's more important to get the oil flowing quickly, with a vw that has an oil cooler the second number is not as important. fwiw 5w-40 will serve your purpose.
    Mar 6th, 2002
    Morris Plains/Parsippany, NJ
    1998 GTI 2.0
    05-04-2012 09:41 AM #3
    The only cars that should be getting 10w-60 oil are BMW M3's, M5's, and M6's. And even then, only Castrol TWS 10w-60 is approved (in the US, I believe it's called Castrol Edge in other markets). Liqui-Moly isn't.
    Stick with a full synthetic 5w-40.
    1998 GTI 2.0
    1993 Jeep ZJ 4.0
    World Automotive
  4. n00b atarekvw's Avatar
    Feb 21st, 2011
    cairo, Egypt
    03 VW GOLF GTI
    05-04-2012 10:02 AM #4
    thanks for you advise, ill stick to a 5w-40 oil that's vw approved
    what about the Liqui Moly Top Tec 4100 5W-40??? its not fully synthetic but synthetic tech oil
    here is the tec data
    http://www.liqui-moly.de/liquimoly/m...%204100_EN.pdf
  5. 05-04-2012 11:21 AM #5
    You'll be ok w/a 5w-40. 40 weight essentially has a built-in margin for oil temps up to 120c. idk what products are available there, but 20w-50 synth should be the thickest you need. Valvoline makes a good 20w-50. Skip 10w-60, it sheers down fast.
    One other option is 5w-50, it's the best-selling grade of Mobil 1 in Europe. You can get it in USA at AMG dealers, or use the Syntec 5w-50, an amazing product.
    US guys reading this should think twice about Mobil 1 15w-50 "Red Cap". I hear bad things about it. Syntec 5w-50 is easy to find, afaik, KMart carries it.
  6. Member rickjaguar's Avatar
    Apr 23rd, 2009
    Van. Island, BC
    07 GTi.. fun times
    05-04-2012 08:55 PM #6
    I ran LubroMoly for about 5 or 6 OCIs in my FSI. 5000mi oci, 5w40 Synthoil Premium. Submitted a UOA thats floating around here.. anyway, i really like it and would still be using it if i had a local supplier.
    Sent from my 1st generation Motorola brick using Tapatalk
  7. 05-06-2012 03:56 PM #7
    Read your max sustained oil temp and select an oil that will stay above 9cSt at that temp.
    Nov 10th, 2010
    mid hudson valley
    05-06-2012 04:35 PM #8
    Quote Originally Posted by Apexxx View Post
    it's not that complicated, nice graph though all and all. vw's run @195f and the oil runs about 10-15 warmer summer or winter.
