As per the rules here, please include a full Auto-Scan when requesting help. The following video shows how to do this:
Regards.
#1
any idea how i can get the proper codeing to code it corectly i have vcds but still trying to learn it ..
thank you
#2
Regards.
#3
VCDS Version: Release 11.11.3
Data version: 20120401
Friday,04,May,2012,15:17:15:19740
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: 9BWBK61J124030817 Mileage: 391140km/243043miles
Address 01: Engine Labels: 06A-906-032-AVH.lbl
Part No: 06A 906 032 FQ
Component: 2.0l R4/2V 4069
Coding: 00001
Shop #: WSC 00000
VCID: 72E03FA23EB4009
9BWBK61J124030817 VWZ7Z0A4112479
No fault code found.
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 J
Component: ABS FRONT MK60 0103
Coding: 0004097
Shop #: WSC 00000 785 00200
VCID: 3162F0AEAB327B1
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 F
Component: 08 AIRBAG VW6 0202 0004
Coding: 12344
Shop #: WSC 00000
VCID: 3A70D7822644B89
2 Faults Found:
00591 - Seat Belt Switch; Driver (E24)
32-00 - Resistance too High
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 906 J
Component: KOMBI+WEGFAHRSP VDO V06
Coding: 07232
Shop #: WSC 00000
VCID: 2F66F6D6ED066D1
2 Faults Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
01316 - ABS Control Module
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00000
VCID: F0E4B5AAB0B8B29
2 Faults Found:
Address 35: Centr. Locks Labels: 1C0-962-258-III.lbl
Part No: 1C0 962 258 AC
Component: 24 Zentr.Verriegel. 0003
Coding: 00016
Shop #: WSC 00000
VCID: 68D45DCA0868FA9
3 Faults Found:
01389 - Tailgate Open Switch (F124)
27-10 - Implausible Signal - Intermittent
00668 - Supply Voltage Terminal 30
01044 - Control Module Incorrectly Coded
35-00 - -
End ---------------------------------------------------------------------
#4
dome lights will not come on head lights will not come on horn and turn sigs will not come on wipers will not work stuck sideways need help
#5
This looks like a 2 door 2002 Golf so the coding of 00016 is correct, but you may try recoding that module using a non zero WSC such as 12345 to see if 01044 clears after a key cycle.
http://wiki.ross-tech.com/wiki/index...eneration_3%29
I would check the basics including fuses and power/ground to those components and see if the ignition switch (including wiring to it) for melting.
#7
tryed reprograming it keys would not reprogram and did not fix codes eather
