Page 2 of 2 FirstFirst 1 2
Results 36 to 66 of 66
Thread: Two-Piece Rotors
  1. Member Lamfalus's Avatar
    Oct 7th, 1999
    Bay Area, California
    '97 Jetta GLX; '01 GTI 1.8T; '12 Golf R
    05-07-2012 01:55 PM #36
    Quote Originally Posted by ToeBall View Post
    315mm rears
    Hmmmm, VW.com says:
    "Power assisted, dual circuit, vented 345 x 30mm front discs and 310 x 22mm rear discs "
    Old - 2001 GTI 1.8T - Matchstick Red (for sale), 1997 Jetta GLX VR6 - Black
    New - 2012 Golf R - CSG
    Sep 28th, 2011
    Texas
    2012 Golf R; 2012 Tiguan SEL
    05-07-2012 01:56 PM #37
    315mm rears
    No, it's 310 mm for the rear.
    2012 Rising Blue Golf R (Build Thread)
    2012 Night Blue Tiguan SEL w/ Premium Nav
  3. Junior Member
    Feb 21st, 2012
    Dallas, Texas
    2012 Golf R
    05-07-2012 10:31 PM #38
    Spoke with the folks at Racing Brake a few weeks back and they are also working on matching calipers to go with the 345 rotors. These will be designed with the R in mind for piston sizing and brake balance. Soon you will be able to start with a rotor upgrade, and then add on the light weight calipers later if you "feel the need for speed" at the track. This will make for a nice staging on the upgrade pathway. Some additional info on this setup below, which is apparently even closer to being a reality.
    http://forums.racingbrake.com/showthread.php?t=849
    http://www.racingbrake.com/v/images/vw/RB_MK5_R32.jpg
    http://www.racingbrake.com/v/images/vw/_MG_4909.JPG
    IMHO I would not go with expensive rear rotors that don't take much of the braking load and save my coin for the front axle. Racing Brake even has a 330 mm BBK kit for as low as $1655 on the internet. It is said to lower the unsprung weight by a whopping 22 lbs per corner for a total of 44 lbs per axle. That is some serious weight reduction! With lighter wheels and tires, you are down over 30lbs per corner or 60 lbs for the front axle. There is a review out there from some one who did this and was very happy with the results, but I can't remember where I saw it. I can't quite confirm these numbers yet either. When the rotors get a little smaller though, they of course get even lighter and have less rotational inertia. This also helps acceleration as well. At any rate, food for thought on this subject.
  4. Member MasterNele03's Avatar
    May 27th, 2008
    West Palm Beach, FL
    2000 C/W Jetta VRWookie, 2005 Volvo XC90, 2010 CW GTI, 2008 Yamaha R6
    05-07-2012 10:47 PM #39
    Quote Originally Posted by TLud View Post
    Just confirmed. They do offer these for the GTI.
    Yea I know they have then for the GTI, I'm curious if they'll put those in the group buy or start another group buy for us aswell.
    Drive it like you stole it!!!
    XBL GT: MasterNele 03
    Need a crank/cam locking tool for your 2.5T (Volvo), PM me.
  5. Junior Member
    Feb 21st, 2012
    Dallas, Texas
    2012 Golf R
    05-07-2012 10:49 PM #40
    Found that other post with a full review of the Racing Brake 330 mm BBK kit on an R32.
    http://forums.vwvortex.com/showthrea...ew-impressions
  6. Member Lamfalus's Avatar
    Oct 7th, 1999
    05-09-2012 09:18 AM #41
    Quote Originally Posted by takmanR View Post
    Can't wait to see what we end up with. I want to see what a stock R caliper weighs. I'm getting it in my head that I want to remove as much weight as possible from my car.
    Short list:
    wheels - 6lbs x 4 = -24
    Passat hubs = -12 total for hubs and LCA
    Passat lower control arms (above)
    rotors = maybe 5 lbs each up front and 3 rear? I'll estimate -16 total
    battery (not relo, lightweight Li-Po replacement) -30lbs
    calipers = -5 lbs total?
    That's -87lbs, maybe conservative on some of that. Would be great to say I cut 100lbs of weight from my car w/o going crazy (other than $$$$ of course )
    May 30th, 2010
    Houston, TX
    10 JSW TDI, 12 R
    05-09-2012 09:26 AM #42
    Quote Originally Posted by Lamfalus View Post
    Short list:
    And apart from the battery, all of what you listed is unsprung weight, the majority of which is rotating mass.
  8. Member sh{}e's Avatar
    Aug 6th, 2004
    Maryland
    2012 GLI Autobahn
    05-09-2012 09:27 AM #43
    Short list:
    I'm thinking of doing the same thing. I might get some really lightweight wheels and save 10lbs per corner. There is an easy 60lbs+ to shave with wheels and rotors. The only thing I will not do again is get a lightweight battery. It sucks in the winter time when it comes to being consistent in starting the car.
  9. Member Wlfsbrg2.0T's Avatar
    Mar 29th, 2009
    ATL
    2012 Golf R
    05-09-2012 10:36 AM #44
    Short list:
    Yes! I want to be in the lightweight club too!!!
    My plans are similar to yours, but I probably won't change the hubs/LCAs.
    My goal is -100 lbs through wheels, rotors, maybe calipers, battery, carbon fiber hood (painted to match), and the removal of some unnecessary things.
    Tornado Red 2012 Golf R Base 4-Door APR Stg 1 KW V3's BC Forged RS41 Wheels HPA Dog Bone Mount
    Sep 28th, 2011
    Texas
    05-09-2012 11:09 AM #45
    The 330 mm SBK piqued my interest as well, and I agree with you that the best bang for the buck is in the front. That said, I'm going to upgrade to the standard size RB rotors and possibly do the front caliper upgrade when they finish it.
    Quote Originally Posted by sh{}e View Post
    Exactly. I saved 8 pounds of rotating mass per corner with wheels and tires. Saving an additional 8 pounds of rotating per corner in front and 3 pounds per corner in rear would give me a total savings of 54 pounds of rotating mass, which is huge.
    Oct 23rd, 2006
    2012 Golf R
    05-09-2012 11:13 AM #46
    Great, now you guys are telling me there's calipers on the way as well? You're spending too much of my monies!
  12. Member Lamfalus's Avatar
    Oct 7th, 1999
    05-09-2012 12:33 PM #47
    I know!
  13. Member Lamfalus's Avatar
    Oct 7th, 1999
    05-09-2012 12:34 PM #48
    Bay Area California so not much winter to speak of.
  14. Member
    Oct 23rd, 2006
    2012 Golf R
    05-09-2012 03:55 PM #49
    Put any thought in to the VWR BBK? Looks like a 7-8lb savings per corner with big meaty 352x32 rotors. The cost compared to the RB kit in development looks to be very close.
  15. Member
    Sep 28th, 2011
    Texas
    05-09-2012 04:32 PM #50
    Quote Originally Posted by webcrawlr View Post
    It looks like a great kit also, but like I said earlier, the stock brakes perform just fine for my purposes. Unless I win the lottery and my schedule miraculously opens up, the amount of time my car will spend on a high speed track will most likely not justify getting a BBK. At this point, I just want lower dusting street pads with good modulation and lighter two-piece slotted rotors (also saves 8 pounds per corner in front). Odds are, I won't ever touch the calipers.
    My only concern with the VWR BBK (and possibly the RB BBK) would be for those guys who want to run 17" wheels on the track, which won't work. That's where that 330 mm kit becomes an interesting option.
  16. Member Ryan E.'s Avatar
    Oct 1st, 2002
    Huntington Beach
    2008 CW R32, 2003 1.8T GTI, 1974 2002 tii
    05-09-2012 04:43 PM #51
    just wanted to mention I've had great success with the rotors, last years HPDE season I beat on the rotors event after event and they still look amazing running Carbotech 1521's for the street and XP20's for track use.
    Here's some teaser pics of the Caliper Replacement, I should be fitting them for testing in the next few weeks.
    http://forums.vwvortex.com/showthrea...nt-Teaser-Pics
    Rigi Cola.
    "The VR6 was an orchestra of well-tuned cylindrical delights." - jalopnik.com
  17. Member
    Sep 28th, 2011
    Texas
    05-09-2012 04:49 PM #52
    Quote Originally Posted by Ryan E. View Post
    6+ pounds of weight savings on top of the 8 pounds from the rotors. Wow.
    Ryan, do you mind sharing your thoughts on the RB rotors with the 1521 pads? Initial bite, modulation, noise, dusting?
  18. Member
    Jun 6th, 2006
    Denver
    2012 Golf R
    05-09-2012 04:57 PM #53
    Since it looks like testing is under way, any idea if the calipers will clear stock Golf R wheels?
    fingers crossed...
  19. Member
    Sep 28th, 2011
    Texas
    05-09-2012 04:59 PM #54
    Quote Originally Posted by Atl-Atl View Post
    fingers crossed...
    Both the VWR and the RB front BBKs will clear the Talladegas.
  20. Member Ryan E.'s Avatar
    Oct 1st, 2002
    Huntington Beach
    05-09-2012 09:56 PM #55
    I'm a huge fan of Carbotech after using the 1521 and XP20 pad with RB rotors. The 1521 have great release and modulation. The MKV R32 front brakes are known to be very twitchy in stock form, the 1521 pad removes some of that twitchiness while providing excellent low/high speed modulation/release.
    The 1521 has less dust than stock and they wear well, not too fast. They work great cold with good torque and you never have the ABS kick in on abrupt stops prematurely. I have to say I have had no noise issues too. The overall pedal feel is very enjoyable, I highly recommend.
    If you ever want to track the XP20 are defiantly the ticket.
    I had issue with HP+ pads when I tracked the rotors for the first time because I got them too hot. I then realized that there's no sense in trying to using a dual duty pad for track and street. That might work with the softer metal of the OEM rotors but not with the RB rotors, so I stepped it up to a proper pad that could handle running with the big boys and haven't had any issues since.
    I would like to reiterate that I've never had any pad issues on the street.
    I have a set of Racing Brake ET500 pads for the rear that have been sitting in my garage to be put on for months with the rear 2-piece. I plan to try those out when I put on the test calipers. I believe I'll also be using the ET500's with the RB caliper replacements. So I'll provide some feedback on those after I try them.
    I think you could easily go through 2/3 sets of pads and not have to replace the rotor rings, so not only are you saving weight, the longevity of the product is like no other rotor I've used in the past.
    Rigi Cola.
  21. Member
    Sep 28th, 2011
    Texas
    05-09-2012 10:52 PM #56
    Thanks for the detailed impressions, Ryan. That does it. I was trying to be good, but I'm putting in an order for these rotors.
  22. Junior Member
    Feb 21st, 2012
    Dallas, Texas
    2012 Golf R
    05-10-2012 01:11 AM #57
    Weight loss could be as I see it:
    Everyday driving
    wheels and tires: 8x4=32 lbs
    330 bbk racing brake: 22x2=44 lbs
    Lithium Battery: 30 lbs
    passat hubs & LCA: 12 lbs
    Total everyday weight loss of 118 lbs
    Track day (stage 1) easy
    Spare tire: 31 lbs
    Styrofoam, jack, and tools: 9 lbs
    additional 40lbs less
    Track day (stage 2) just a little work
    Remove rear seat backs: est 40 lbs
    additional 40 lbs less
    This makes for a grand total of 198 of weight reduction for a day at the track! Not bad considering the last 80 lbs is free!!! Anybody else have any ideas?
  23. Member
    May 30th, 2010
    Houston, TX
    10 JSW TDI, 12 R
    05-10-2012 07:30 AM #58
    Have you tried StopTech Street Performance pads? I'm curious on your take. From what I've read, they're also low dust, but grip to the point of almost having too much bite.
  24. Member
    Sep 28th, 2011
    Texas
    05-10-2012 07:59 AM #59
    I ran those as my street pads with the StopTech BBK on my M3. Excellent pad, and I highly recommend. I didn't experience what you describe, but it would be hard to experience too much bite with that car.
    Sent from my iPhone 4S using Tapatalk
  25. Member Ryan E.'s Avatar
    Oct 1st, 2002
    Huntington Beach
    05-10-2012 12:25 PM #60
    awesome, they make the stock brakes a solid package as far as I'm concerned and you can still run 17's if you wanted.
    I've tried EBC Yellows, Reds, Hawk HPS and HP+ along with the Carbotech pads mentioned.
    What you're describing is exactly what I'm talking about with the good low speed Modulation and Release with the 1521, they don't do that where my XP20's for track definitely do that, but I need the extra torque at the track.
    Rigi Cola.
  26. Member nkgneto's Avatar
    Dec 4th, 2004
    West Burbs, IL
    04 VW R32 TRed, 05 Jetta Wagon Blk/Orange
    05-11-2012 01:04 AM #61
    Opti-Coat applications in the Chicago Area! * United Motorsport Flashing in the Chicago Area *
    Luis has been the most responsive person I've dealt with in the VW world. There's a lot of big name shops that could learn a lot from his customer service skills.
    Quote Originally Posted by Polz View Post
    All of the above four points. Plus I have received great service from Jeff and from Luis at Automobile Day Spa.
  27. Junior Member
    May 10th, 2012
    Heidelberg, Germany
    2012 Golf R Rising Blue 4dr w/Navi 2012 Passat TDI SEL (Wife car) 2010 Jetta TDI (sold)
    05-11-2012 03:44 AM #62
    oK guys been reading the forum for a while now. I am no car mechanic by any means, but I do want to spruce up my R. Especially with living in Germany I want to be able to stop pretty quick because people like to pull in front of you when your at 110 MPH. So with all that said, where can i get a brake upgrade at? I would like to jump in on a group buy or anything.
    TLud i have seen your build on your R and it is pretty impressive. I am going to be using some of your ideas and incorporate them into my R build.
    Thanks for the information
  28. Member nkgneto's Avatar
    Dec 4th, 2004
    West Burbs, IL
    05-21-2012 08:12 PM #63
    This was just posted by Ryan.E here.
    Reminder the rotors are 345x30
    Just wanted to update everyone on long term wear. I measured the rotors after 9 track events and I only have .18mm of wear, that's Huge!
  29. Member
    Mar 28th, 2012
    Houston, Texas
    2012 Golf R CSG
    05-22-2012 08:18 AM #64
    If interested, shoot me a PM. We can get these for a lot less than the list price. Thanks to Peteski for the hookup.
    This.
  30. Member
    Oct 23rd, 2006
    2012 Golf R
    05-22-2012 10:29 AM #65
    Waiting on hats to arrive at RB then I'll be running these as well. Dropping 22lbs of rotating mass from new wheels and tires was pretty noticeable. I can't wait to see what another 20lbs feels like.
  31. Member
    Sep 28th, 2011
    Texas
    05-22-2012 11:39 AM #66
    Quote Originally Posted by sgt_bo View Post
    If you look at my build page, you can see what I'm going with. I got my RB Rotors from Luis at Automobile Day Spa; I got Carbotech 1521 pads directly from Carbotech; I got StopTech stainless steel brake lines from Dion at Achtuning; and I picked up some ATE Super Blue brake fluid locally. Shoot me a PM for more info on pricing.
    Quote Originally Posted by nkgneto View Post
    Wow, that is impressive. Really impressive. Improving longevity and durability to my setup will be yet another great benefit of this upgrade.
    +1 It's funny, my rotors were at my door step 2 days after placing the order. Just waiting on the SS lines.
