That picture almost looks like its out of a playstation 3 game. Amazing!
#1
Here’s a cool image of the final F-22 aircraft (Air Force serial number 10-4195) delivered to the U.S. Air Force on May 2, 2012.
The aircraft will be assigned to the 3rd Wing at Joint Base Elmendorf-Richardson (JEBR), Alaska, where F-22s already equip the active duty 90th and 525th Fighter Squadrons and the 302nd FS, an Air Force Reserve Associate squadron.
The photograph is particularly interesting because, according to the EXIF data shown by Flickr, it was taken with a Hasselblad H4D, a high-end professional, costly (depending on the model the price range is comprised between 27,000 and 44,000 USD), medium format DSLR camera, that is famous for its super-high resolution images.
The most expensive camera for the final most advanced (and troubled) stealth fighter plane ever built.
#2
#3
You say that as if it's surprising. The military has frequently been at the forefront of methods to record video and audio, even just for documentation. I can certainly see the value in having very high dollar, high resolution photography equipment for military photography. Sure, this one is just a glamor shot, but I'm sure the press core or whatever they are called do a lot of photo shoots that result in images that are closely studied with a lot of thanks given for high resolution.
Or... hey, it's the feds. They spend money like water flows downhill.
Either one of those two possibilities is valid.![]()
#4
If it's not foggy
and you have your fog lights on
you are a doofus.
"Pro Tip: Don't **** with people who've been trollin' longer than you've been alive." - OOOO-A3
#5
#6
That picture came from Lockheed, I assure you.
#7
#9
I would reply, but I'm feeling a little light-headed and dizzy. I need to go outside and get some air...
"Giving money and power to government is like giving whiskey and car keys to teenage boys." -P.J. O'Rourke
#12
If it's not foggy
you are a doofus.
#13
#14
Yeah, and don't run into any trees and then not remember it later so you can be blamed for hitting the trees but not credited with saving the post.
If it's not foggy
you are a doofus.
#15
Thank you for posting such an exilerating picture. I just finished watching a Nat Geo on area 51 on the SR-71.. I turned here after it was finished.. Getting my fix in for the weekend..
FS //// MK4 Heater core and Dash ////
