Results 1 to 10 of 10
Thread: Square nylon peg that drives the speedo
  1. Member imjayowen's Avatar
    Mar 9th, 2009
    Columbus, Oh
    '83 diesel rabbit
    05-04-2012 04:20 PM #1
    Mine rounded out from improper installation. Anyone got a part number on this or advice on a replacement. Junk yard isnt an option
    Nov 11th, 2002
    North Iowa
    '84 Rabbit VNT-15, '91 golf TD, '87 Jetta GLi, '84GTi 1.7TD, '84 Rabbit diesel
    05-05-2012 12:11 AM #2
    Only advice i have is the square plastic slides into a rubber tube that pulls off the cable.
    Rubber and end could be swapped from one cable to another,..
    if you have a spare cable that won't fit your ap.
  3. Member Charcoal_Grey's Avatar
    Jul 22nd, 2008
    San Diego, CA
    95 jetta vr6 (rip) 95 cabrio Vr6 in PA, 2012 Harley Forty-Eight
    05-05-2012 01:12 AM #3
  4. Member
    Dec 13th, 2009
    Southern MN
    1987 VW Cabriolet, 1982 VW Vanagon Westfalia
    05-05-2012 08:54 AM #4
    Is the problem the cable or the gear? If it is the cable, I might have one on a parts Cabriolet. If it's any good, I'd let it go for little more than the price of shipping
    Nov 11th, 2002
    North Iowa
    05-05-2012 11:00 AM #5
    You might be able to pull the plastic part out,
    flip it over
    and shove it back in.
    Maybe.
    Let us know if it works.
  6. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    little d BIG D - texas
    81 VW Rabbit 1.7L EN 4-speed 020 GP, 78 VW Rabbit 1.5L EH 4speed 020 GC->GP
    05-06-2012 05:28 AM #6
    Quote Originally Posted by imjayowen View Post
    hrrmmmm nylon....
    ahhh yes those are factory
    most aftermarket speedo cables are now form fit metal (basically squashed cable) to fit the square holes
    my 81 has the nylon type....
  7. Member imjayowen's Avatar
    Mar 9th, 2009
    Columbus, Oh
    '83 diesel rabbit
    05-08-2012 04:28 PM #7
    Man this has been a bitch. Just pulled apart 4 cars at the junk yard. None of them had this part. Tried to buy a cable and they all were some weird combinations like clip in backs and stuff
  8. Member crewsr's Avatar
    Nov 3rd, 2005
    Houston
    1984 Diesel, 1981 Cabby
    05-09-2012 10:38 AM #8
    Go to hobbylobby or a good hardware store that has a selection of 'hobby' brass tubing and look for a piece that has a similar cross section. Alternatively, get a nylon fastener or bolt and use a dremel or small black plane or similar tool and square it up. It would probably take all of 15 minutes...
    Nov 11th, 2002
    North Iowa
    05-10-2012 11:41 AM #9
    Did you try pulling the plastic piece and flipping it, like I suggested?
    Just testing my invisibility.
  10. Member
    Nov 11th, 2002
    North Iowa
    05-14-2012 03:33 AM #10
    It seems likely that my cloak of invisibilty is still firmly intact,
    but it's possible he stopped postiing because it worked great and he no longer needs us.
    orr it was such a simple fix
    well maybe he's just too embarrased to come back and post letting us all know how easily it worked.
    I had a similar problem yesterday, screwed the speedo cable on and still didn't have a speedometer.
    Unscrewed it to find the plastic, square peg missing.
    I pulled one out of another (with my fingers, no special tools, ha)
    flipped it for fun and shoved it into the cable of the '84 Rabbit project.
    Taa daa speedometer/odometer.
    Something else I'll need to keep a spare of and remember where I put it, ha.
    Oh well, a square peg doesn't take up much room.
