Yes. Just make sure your flywheel matches the size of your clutch kit
#1
I just picked up an 020 FF 5 spd Transmission. I believe its from a Mk1? Its going on my 2.0 ABA for a rabbit pickup project. What size clutch and flywheel setup works with this? I found one source that said this trans used a 190mm. But I also read things about people mismatching different clutch and flywheel sizes? Can a 200 or 210mm setup fit this? I havent found many new flywheels available other than the 210mm.
Thanks for your help.
Troy
#2
#3
#6
would the starter be the same?
#7
#8
