Results 1 to 13 of 13
Thread: 79 Diesel L electrical help
  1. 05-04-2012 10:47 PM #1
    I picked up a 79 Diesel L, had been sitting since approx 1996, I have got it running and all my lights working properly (and fixed the ghetto headlight wire job).
    It has Factory air and the optional 5sp
    Yes I have a Bentley's more than one for MK1 and several other manuals also
    Now I am trying to sort out the following;
    cabin blower fan not working (this is the type with 3 levers for the stacked on top of each other)
    Temp Gauge not working
    Fuel gauge not working (tank is full to the gills as I picked it up)
    Washer pump (works when hot wired)
    Radiator Fan (works intermittently when cold is selected but otherwise not)
    I am not great with electrical, just very basic stuff
  2. Member Bowcaster's Avatar
    Dec 8th, 2009
    Winona, MN
    '84 diesel Jetta, 86 vanagon
    05-05-2012 03:04 AM #2
    Quote Originally Posted by mnaussie View Post
    Start with new relays and a can of electric cleaner. Gooooood luck.
    May 4th, 2012
    Netherlands
    1983 Golf Mk1 LX
    05-05-2012 03:08 AM #3
    Exactly start cleaning the wires. After this use a voltmeter to check if there is juice coming.
    This could be a relais, wire or fusebox issue.
  4. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    little d BIG D - texas
    81 VW Rabbit 1.7L EN 4-speed 020 GP, 78 VW Rabbit 1.5L EH 4speed 020 GC->GP
    05-06-2012 05:41 AM #4
    fuel level sender inside pump probally rotted, remove seat,remove cap, pull level sender
    you can check it for ohms before pulling it out
    if you have a simple 2 pin then:
    27-33ohms is full
    233-270ohms is empty (varies)
    anything over 300ohms is bad, need to clean it
    REPLACE THE BIG O RING!!!
    other reasons:
    the voltage stabilizer on the cluster needs to be replaced or tested
    it controls several items in the dash
    it has 3 "feet/legs" and its an IntegratedCircuit (IC) you will know it....
    relay
    check your X relay (aka load relay)
    if your defroster unit doesnt work (12v) then that is most likely the issue
    it controls wiper, blower, defroster, etc (all the heavy amp items)
    if your radiator fan only works when "cool" is selected on the AC then you need to check the switch on the radiator
    there is a bypass relay here which is designed to do this, its a feature of AC cars
    the switch is located at the lower driver side under the battery at the bottom
    dont pull the switch out, just check it
    jumper the two wires together and the fan should come on no matter what (car off)
    if they dont then you have a problem
    then you can test the OHMS resistance of the switch itself as it heats up
    start when cold, check ohms
    start car, watch if ohms drop as the radiator temp warms up
    ok, washer pump
    id start by checking the wires on the column
    the bentley has troubleshooting information for this
    find it, it will help you
    otherwise as you have most of it apart checking it
    verify the contact on the pull lever is actually making a contact it may be dirty or bent
    you cant really see it unless you remove the steering wheel etc and have the switch in your hand
    let us know what worked, what didnt, if you have more questions
    and post pictures, we luvv pictures.........
    thanks
  5. 05-06-2012 10:41 AM #5
    Checked the sending unit last night I need to check again today (I think I got 33ohm)
    I will take some pictures and try to get them posted, I have a feeling I am missing the load relay? The relays on the fuse box are the following
    Glow plug
    left side flasher
    right side flasher
    321919505
    AC Fan Relay 171959143A on the steering column
    Relay for the radiator fan 321919505 also on the steering column
    The wipers work (both speeds) and when I pull the lever for the washer the seat belt/brake warning lights light up?
    The radiator fan kicks in when you bridge the thermo switch on the radiator
    That's about where I am at right now, I have the steering wheel pulled so I will check the washer switch on the column today.
    Thanks for the tips and advice so far
  6. 05-06-2012 10:31 PM #6
    Ok so I now have the washer pump working, but the seatbelt/brake light light up on the dash
    I have power at the rear defrost switch
    Radiator fan works when you jump the sensor in the radiator under the battery
    Radiator fan kick in at different speeds when the wires are jump on the relay for the AC
    Still no cabin fan, and I have not run the car today to warm it up and check resistance on the thermo switch.
  7. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    05-06-2012 10:54 PM #7
    good news is that you tested the wires on the thermo switch and the wires work
    therefore your switch is probally bad and needs replacement
    you should go stock and match it to your thermostat in the waterpump
    or just replace it exactly to the same temp stamped on the switch
    AC radiator fans have high and low speed (3 pin connectors)
    i am not sure why your blower does not work, more digging should illuminate this
    the seatbelt light is troublesome, mine will generally illuminate doing wierd things no matter what
    ignore it at all costs unless you must fix it
    i blame it mostly on the strange wiring of VW
    my 81 the seatbelt light flicks on every time the rad fan kicks on or off (relay related) it is only on for a split second
    ignore it
    my 78 similar situation, the light works normally (it goes off) but it will remain on and slowly slowly slowly fade away after shutting the car off
    ignore it....
    find the manual page for the relays & fuses in your bentley to check the fusebox
    i believe socket K is the load reduction relay
    you can test this relay by removing it and shorting pin 85 to 86 if it clicks then it works
    if no click then it does not work
    since your wipers and your rear defrost unit work (via the switch) then your load relay works
  8. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    05-06-2012 11:15 PM #8
    found this for you
    this item usually controls a few items on the dash
  9. 05-08-2012 12:41 AM #9
    Will check that one tomorrow thanks
    I go the heater / AC fan sorted, Dam Mice eat through the power at the bottom of the resistor bus next to the motor! Soldered a new wire in and all seems good
    I did check and I am getting power to the instrument panel so it might be the voltage stabilizer I will check it tomorrow.
    I am getting there slowly
    Thanks Guys
  10. 05-08-2012 09:00 PM #10
    It ended up been the voltage reg, I just swapped one from another cluster I had and Bam!
    Thanks for the help guys
    I only have the thermo switch to swap out and replace my windshield and should have this little rabbit on the road
    Now time for a few of these
  11. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    05-10-2012 12:02 AM #11
    right on, glad you got it running
    troubleshooting and diagnosis helps save the day again
    Nov 11th, 2002
    North Iowa
    '84 Rabbit VNT-15, '91 golf TD, '87 Jetta GLi, '84GTi 1.7TD, '84 Rabbit diesel
    05-10-2012 11:36 AM #12
    Thanks Guys
    If the heater fan hasn't melted pin 19 of the blue plug yet,..
    you should relay it on high.
    I just put the relay next to the fan in the rain tray and ran fuse/wire from the battery.
  13. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    05-15-2012 06:27 PM #13
    Quote Originally Posted by fatmobile View Post
    good tip, that is about 20-30 amps flowing through that one wire from the switch
