Results 1 to 3 of 3
Thread: Overheating 2002 Passat
  1. 05-05-2012 12:42 AM #1
    My 2002 Passat 2.8 v6 overheats within 20 minutes of driving in the city. I don't have heat when this happens however it will occassionally produce heat and the temperature guage will fall about 25% at the same time. Then the guage maxes out again and I lose heat.
    Is this the thermostat or the water pump failing?
  2. Member passatv6AF's Avatar
    Nov 4th, 2011
    Chicago
    B5 5MT UNITRONIC TUNED, B7 6MT TDI
    05-05-2012 08:00 AM #2
    Could be either one or both. How many miles you got?
  3. Member Zookie's Avatar
    Jan 5th, 2004
    Toronto, Bombay, Kuwait
    Porsche 996 C4S, VW Passat B5.5 Sedan & VW Jetta VI Sedan
    05-08-2012 01:50 PM #3
    If your Waterpump is Broken, then you car would just Overheat Completely, Gauge will not Move. So from your description it sound like your T-Stat is Stuck Closed. I had similar problem My T-Stat was Stuck Open and my car always ran Cold.
    If its a CTS Issuse you would get Irratic Temp Reading but it will not coz your car to Overheat.
    Unfortunatly for you, yours is a V6 so just to change the T-Stat everythings gotta come out from the Front anways, so while you are at it, might as well Do the Complete Timing Belt Job including the Waterpump and change the T-Stat and CTS anyways
    Zook – SCB | www.SportsCarBoutique.com Follow Us On www.facebook.com/SportsCarBoutique
    BOUTIQUE & TUNING: 905-731-0700 | 85 GLEN CAMERON ROAD, TORONTO, ON L3T 1N8 zook@sportscarboutique.com
    AUTHORIZED DEALER: Alpinestar, BMC Air Filter, Braille Battery, EVOMS, HJC Helmets, H&R, HANS, HRE Wheels, Pagid RS, Racelogic, Recaro, Motul, Schroth Racing, Stilo.
