Results 1 to 5 of 5
Thread: 1997 VW Jetta 2.0 P0304 Code Hell
  1. n00b
    May 5th, 2012
    1997 Volkswagen Jetta GLS VIN A 2.0
    05-05-2012 10:25 AM #1
    Please if absolutely anyone can shed some light on my current situation, I would be most grateful. I bought this car October last year, and have been dumping money into it ever since trying to get it back to ground zero. I am down to a P0304 OBDII engine code, Ive done everything that I know to do including taking the car to a mechanic (he had it for a month and a half and couldnt figure out the problem). Heres a list of work Ive done so far.
    -New Bosch Double Platinum Plugs
    -New Autolite Wires
    -New Bosch Distributor, Cap, Rotor
    -New Timing Belt
    -New Ignition Coil
    -New Fuel Injector (#4)
    -New EVAP Purge Valve
    -New PCV Valve
    -New Oil Cooler Seal
    -New Coolant Hoses (All Upper and Lower)
    -New Thermostat
    -New New Coolant Temperature Sensors (Both)
    -New Brakes Front and Rear
    Thats just the stuff I can remember off the top of my head. I am tired of throwing my time/money at it and already have about 3 times more invested in it than I paid for it! Please help, is there anything else that may be causing the misfire? Here is a little more information on it. I bought the OBDII reader from Advance Auto and when I clear the misfire code after the motor has warmed up, it will stay off for the rest of the day (as long as the motor is kept warm). However, when the motor is cold and i start it, the light comes on within 3 to 5 minutes everytime. If you need to know anything else then just ask. The Car has 182,500 miles on it. Thanks
  2. Member Krieger's Avatar
    May 5th, 2009
    Orlando, FL
    Turbocharged 2004 Civic SI with K20/K24 engine swap, 2006 Audi A3
    05-05-2012 10:50 AM #2
    wrong forums. try the 2.0 forums specific to your motor. the people around here won't know much about this one.
    2006 Audi A3 | 2.0T | 6MT | APR Stage 2+ | Fully loaded ECU | FK grill | EJ CAI | BSH TBP |EJ DV Reloc. | Eurojet TBE | EuroJet Catch Tank | Cross drilled and Slotted Rotors | EBC "Redstuff" Kevlar | Raceland Coilovers | Forge Side to Side Short Shifter | Forge Front to Back Short Shifter | Devil's Own DVC-30 Methanol injection | BSH RSB | BSH Motor mount Kit | 42 DD Shifter Bushings | HPFP Stage 1 upgrade |
  3. Member Krieger's Avatar
    May 5th, 2009
    Orlando, FL
    05-05-2012 10:50 AM #3
  4. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    05-05-2012 10:50 AM #4
    You are in the wrong forum, this is for the 2008.5+ 2.0L Turbo TSI motor found in the MKV and MKVI GTI
    :APR -stage 2 :BSH -Intake,Mounts,RSB,TB Pipe :Whiteline -A.L.K.,Endlinks
    :Devils Own -DVC-30+Direct Port Injection :BC Racing -BR Coilovers :Flik-FTD :OSIR
    :Neuspeed -Insert,Brake Lines:Eurojet -Ceramic Coated DP :DEFI :Unibrace :Tyrolsport :Bildon :Hawk
    TSI FAQ: http://forums.vwvortex.com/showthread.php?4042736
  5. n00b
    May 5th, 2012
    05-05-2012 12:34 PM #5
    Thanks, I'll repost it there.
