No baffles, just a small sump type of thing with a screen in it. You might check it to see if it is sealed and holding pressure or that the tube from the sump to the outlet is not perforated.
Are mk1 gas tanks baffled? I am just wondering because I have an 84 GTi with a 1.8L JH and I keep getting a lot of hesitation when I am going uphill and the tank isn't full.
FS:Sunroof Deflector
they are internal.
By removing the fuel sender, then you can remove the screen and perform a visual on the tube, as I don't know of any adults with hands small enough to reach the tube, w/o cutting on the tank.
