VWVortex.com - Driveway power swing gate operator motor reccommendation
    Results 1 to 2 of 2
    Thread: Driveway power swing gate operator motor reccommendation
    1. 05-05-2012 02:55 PM #1
      I have a 10' iron driveway swing gate that is currently manual. I would like to install a power gate. My gate is new, and has ball bearing hinges and requires little resistance to open/close. I can push it with my pinky. It is about 200 lbs.
      I want a power swing gate operator, but do not have the room behind/beside the gate for the type that has a tower and motor with arm. I need the type that has the motor built into the arm. I have researched several options online and am even more confused as there are good and bad reviews on them all. I will be installing it myself, and have a pretty good mechanical inclination. Power won't be a problem; there is a source nearby.
      My price range is up to $800. I have a few criteria that I would like.
      -Soft open & close
      -Ability to add sensors (input/output) later
      -Keyed manual release
      -Battery operated/backup
      -Reliable (obviously)
      I really am looking for first-hand experience, weather it is what worked for you, or what has not. Even better is someone in the trade that can give me advice.
      Thank you in advance!!!
      Brian
    2. Senior Member spockcat's Avatar
      Jun 5th, 2003
      West Coast, not that west coast. Bay area, not that bay area.
      11 328i Touring, 16 Colorado Crew, Versys
      05-06-2012 09:46 PM #2
      Apparently not many gate owners here. Maybe you should try the Garage Journal forum.
      Touareg Audio Accessories - Keyless Start - Paddle Shift
      If you use Tapatalk, you aren't seeing the whole message. Tapatalk shortens GIFs, cuts URLs and deletes signatures.
