Results 1 to 2 of 2
Thread: Allroad SAI secondary air pump removal DIY
    Jan 27th, 2007
    NH
    2001 Audi TTQ TDI, 2001.5 B5 S4, 2002 2.7t AR 6spd
    05-05-2012 02:36 PM #1
    Anybody know where there is a good description to remove/replace the secondary air pump?
    thx
  2. Junior Member Ixomeneus's Avatar
    Nov 27th, 2011
    TX
    '04 allroad 2.7T, '10 A3 Quattro
    05-08-2012 10:43 PM #2
    Remove the Y-pipe, then disconnect and remove the EGT sensors. The secondary air injection solenoid valve (N112) is secured to a bracket below the control modules for the EGT sensors. Disconnect the harness connector from valve and slide bracket off studs at the intake manifold with vacuum lines connected. Then disconnect the vacuum lines and remove the valve from the bracket.
