Results 1 to 17 of 17
Thread: TCL: learn me D3 Audi A8's
  1. Member 93VR6Passat's Avatar
    Jan 26th, 2005
    Hagerstown MD
    2007 Jetta, 1983 GTI
    05-05-2012 04:59 PM #1
    Looking to get some more info on these luxo barges. Prices for 05-06's are in the mid to upper 20's, and after driving one I feel that I need one in my life Hopefully I can get some first hand experience, and realistic things to look for, not the oh its a 80k car it will kill you in maintenance blah blah. Id even like to hear some things about a comparable 7 series or mb
    Rule 1:
  2. Member Vettes, Volvos and VWs's Avatar
    Mar 5th, 2006
    Sudbury, ON
    76 Corvette, 94 960, 01 Passat Wagon, 02 Jetta 1.8T, 07 A6 S-line
    05-05-2012 05:12 PM #2
    One word: sex
    Sorry I can't be of more help
    Quote Originally Posted by Baconator14 View Post
    vettes, volvos, and vws for president
    Quote Originally Posted by UAlvarez View Post
    you're a boss. your sig is appropriate
    My Weak Shiz l Milk █Bg█ Mafia
  3. Member woofster's Avatar
    Dec 16th, 2002
    Toronto, Ontario, Canada
    05-05-2012 06:42 PM #3
    If you're just looking for TCL feedback, this thread is a good start:
    http://forums.vwvortex.com/showthrea...le-car-Audi-A8
    2002 Audi A4 1.8T Quattro
    2003 Acura MDX Touring
    Sorry, I can't think of anything witty for my signature.
  4. Member texas03''s Avatar
    Dec 3rd, 2002
    Henderson NV
    2013 S4 on order--2004 TJ --1951 M38M1 --MB 300SD
    05-05-2012 06:43 PM #4
    probably one of the most reliable new audis. That being said it does have some issues, front struts leak air, thermostats are know to stick and cause it to overheat, and the nav screen motor will strip out. All these are fairly easy to do yourself but parts can be expensive. they also eat up tires and front upper control arm bushings.
  5. Member Jan PL S6's Avatar
    Apr 22nd, 2010
    NJ
    1995 urS6, 2005 A8L
    05-05-2012 06:53 PM #5
    Absolutely amazing car. My only complaint with mine is that its too big but if you like luxury barges then this is the car for you.
    Things to look out for when you're looking at examples close to 100k miles. You want to make sure that the timing belt has been serviced because it can be pricey and it can get technical so if its not done, make sure you have a little extra cash to put into it. GET VAGCOM. If you plan on doing your own maintenance it is absolutely necessary. You need it in order to replace your brakes and get rid of the slightly annoying service reminder on oil change intervals. One other thing to look out for when shopping. Some guys have complained of a "hoot" noise coming from the transmission during shifts under slightly heavy load. Some guys freak out and have Audi replace the transmission fluid for you to some high performance stuff and that supposedly eliminates the problem. Other guys just live with it since Audi tells you to not change the transmission fluid . Its something to look out for though.
    I have had mine for just short of 50,000 miles and the car has performed wonderfully. I do not recommend it though if you do a lot of tight city driving because it could be annoying with parking and such, the thing is huge. My father bought his at the same time I bought mine and he swears he will never buy another car other than an A8 (so far he has kept his word from a D2 to a D3 now). His has had a small problem though. He has the electronic door assist that closes the doors for you when they're not shut properly. All four of his failed one by one and were annoying to replace but thankfully it was an option on these cars (one that mine does not have ). Other than that there are no problems to report. Both of ours have performed faithfully and never left us stranded, nor have they broken down on us.
    I always ponder selling mine for an S4 only because I prefer something smaller and sportier but I always find it hard parting with this magnificent car.
    Edit: what gentleman would I be if I didn't show my little lady
  6. Member Jan PL S6's Avatar
    Apr 22nd, 2010
    NJ
    1995 urS6, 2005 A8L
    05-05-2012 07:12 PM #6
    Quote Originally Posted by Crob View Post
    Timing belt on a luxury car?
    Pfffffshhfffft.
  7. Member 93VR6Passat's Avatar
    Jan 26th, 2005
    Hagerstown MD
    05-05-2012 07:13 PM #7
    Thanks guys, I've been looking at ones that are around 70-80k miles. I have access to a vagcom and would be taking it along and scanning any car I would be interested in. Ive been checking on some maintenance parts to see some costs and they seem to be somewhat reasonable considering this was an $80k new, even the timing belt kit looks to cost under 600 for everything and would just eat a day of my time to change it. Overall they seem to be a pretty decent deal from what I can tell. Looks like its time to push the Jetta and do some real searching for the right one
  8. Member Jan PL S6's Avatar
    Apr 22nd, 2010
    NJ
    1995 urS6, 2005 A8L
    05-05-2012 07:19 PM #8
    Quote Originally Posted by 93VR6Passat View Post
    Go for it
    Doesn't hurt to check them out and I have yet to hear someone go wrong with their choice in this car. If you have any questions feel free to PM me.
  9. Member 93VR6Passat's Avatar
    Jan 26th, 2005
    Hagerstown MD
    05-05-2012 07:23 PM #9
    Thanks Jan, Ill certainly keep you in mind if I have any quick questions
  10. Member Jan PL S6's Avatar
    Apr 22nd, 2010
    NJ
    1995 urS6, 2005 A8L
    05-05-2012 07:41 PM #10
    VAG Iron blocks plus timing belt = Iron block engine with engineered obsolescence if the timing belt is never serviced. Otherwise they'd probably just run forever and VAG can't have that noise... can't make money on engine replacements if timing belts aren't snapping.
    Yes, yes I know. The big bad VAG man is always out to get us They did switch over to the chain in a few years but then you get this nasty thing which also needs to be replaced around the same time.
  11. Member eurotekms's Avatar
    Feb 10th, 2002
    Arizona
    05-05-2012 07:55 PM #11
    Quote Originally Posted by Jan PL S6 View Post
    Thats a beautiful image.
    Been eyeing some D2's lately.
    x
  12. Member vwb5t's Avatar
    Jun 22nd, 2008
    eastern CT
    64 baja bug, 05 Yukon Denali, 99 passat 2.7t swapped
    05-05-2012 08:13 PM #12
    not sure why, but this picture kinda makes me want to get a high milegae one just so i can pull it and replace those chains, guilds, and tensioners. it looks like fun to me
    Quote Originally Posted by tdogg74 View Post
    The sound is literally like if you put your head in a toilet bowl, pursed your lips, and said "oooooo".
  13. Member Jan PL S6's Avatar
    Apr 22nd, 2010
    NJ
    1995 urS6, 2005 A8L
    05-05-2012 08:58 PM #13
    Quote Originally Posted by eurotekms View Post
    IIRC I'm pretty sure the D2 runs on a belt so unfortunately you don't get to see this engineering mindf*ck on the D2
    Quote Originally Posted by vwb5t View Post
    Not 100% sure if the story is the same on the A8 but I know on the 4.2 V8 on the S4's these chains are located on the back of the engine.. meaning you will have to pull the engine out to toy with it. If you can enjoy this job I offer you a firm handshake
    It's not like VAG can't engineer something that'll last forever... it's that they want you to buy their cars more often.
    I'm actually quite curious as to what car you have found that IS engineered to run forever lol
