Results 1 to 6 of 6
Thread: Is it worth the $$?
    Aug 27th, 2008
    Pittsburgh , P.A
    2002 jetta 2.0 - 97 jetta glx
    05-05-2012 09:03 PM #1
    So looking to do a turbo build on my mk3.
    Just so happens theres a kit a guys selling for $1200 that was originally on a mk4 the was re-pieced together for a mk3.
    It's not complete but hers what it has
    turbonetics t3 63 trim turbo, no shaft play ( doesnt look to have a coolant inlet either. which i havent decided will work or not)
    eip turbo manifold and downpipe (2 and half inch which my exhaust just so happens to be)
    turbosmart wasegate 38mm
    mk3 innercooler
    mk4 innercooler pipping ( will be selling or trading)
    What i think i would still need:
    injectors
    software stage 1 for 6-8psi (prob going with untied motorsports or c2)
    mk3 inner cooler piping.
    various lines and hardware
    So all in all would it be worth 1200 for what he has, or should I talk him down to 1,00 or just let it pass?
  2. Member sleepin gti's Avatar
    Jan 21st, 2011
    clarion pa
    megasquirt 3 powered 95 black gti VRT on a cup kit not slammed. and my minty mk2 jetta wolfy daily
    05-05-2012 10:41 PM #2
    First things first. Maintenance is a must vrt's are a blast tho when done correctly.
    Aug 27th, 2008
    Pittsburgh , P.A
    05-05-2012 11:20 PM #3
    maintenance is good to go hopefully thank god. every gasket/seal has been replaced except for headgasket and cam seal. 88k on the clock timing done at 67. clutch and flywheel stage 1 less than a year old. brand new coil pack, crack pipe, t- stat housing, pcv delete, hopefully nothing else craps out. idk what else would need replaced on the motor itself for low psi
  4. Member sleepin gti's Avatar
    Jan 21st, 2011
    clarion pa
    05-06-2012 10:29 PM #4
    In my opinion go for it, fix stuff as it needs to be. Cuz stuff will. Ask me how I know
    Aug 27th, 2008
    Pittsburgh , P.A
    05-08-2012 03:42 AM #5
    I believe your vrt belonged to Tim from european concepts at one point. If so thats who would be building mine, and where im getting the kit from.
    That vrt made 856whp on a mustang dyno
  6. Member sleepin gti's Avatar
    Jan 21st, 2011
    clarion pa
    05-08-2012 01:51 PM #6
    Quote Originally Posted by vwknight View Post
    you are correct sir
