Results 1 to 31 of 31
Thread: Voice Command VERY loud "Main Menu"
  1. 05-05-2012 09:19 PM #1
    Every time I hit the voice command button on my steering wheel, and the womans voice says "MAIN MENU" - it is SOOOOO DANG LOUD!!! I can't find a setting anywhere to default it to a lower amount...
    Apr 16th, 2011
    Indy, US
    '12 R-Line
    05-05-2012 10:19 PM #2
    Quote Originally Posted by b4scotty View Post
    Nowhere but the volume control itself. Be sure your bluetooth is turned all the way up on your phone, hit the button, and turn the volume knob to change the volume of the voice.
  3. Member choey's Avatar
    Feb 10th, 2007
    All over Eastern PA
    Bagged GTI
    05-05-2012 10:20 PM #3
    LOL now that I think of it that bitch is pretty loud scares me at night sometimes
    @gtijoey
  4. Member intoflatlines's Avatar
    Jun 26th, 2008
    Chicagoland
    Z4 M Roadster
    05-06-2012 12:26 AM #4
    Yep, I have the same issue. Whenever I accidentally hit the voice command button and hear the three note chime, I brace myself for the "MAIN MENU!" shout. Settings don't help. If I leave the volume adjusted for a phone conversation, the voice prompt is too loud, and if I make the voice prompt normal level the phone conversation is very quiet.
  5. 05-08-2012 10:05 AM #5
    Quote Originally Posted by intoflatlines View Post
    +1, that's exactly it. I can't believe there is NO fix for this?!?!
  6. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    2007 GLI (SOLD) / 2010 Pressurized GTI
    05-08-2012 10:10 AM #6
    Damn women. Even computerized ones annoy the hell out of us.
  7. Member FUZE's Avatar
    Apr 13th, 2004
    San Jose, CA
    05-08-2012 11:14 AM #7
    Quote Originally Posted by Squirrel Nuts View Post
    LoL, I just hate how much she repeats me!
    Her: MAIN MENU!
    Me: Call Jennifer at home.
    Her: Do you want to call Jennifer - at home?
    Me: Yes.
    Her: Calling Jennifer - at home.
  8. Junior Member
    Sep 3rd, 2011
    MA
    2012 GTI
    05-08-2012 02:18 PM #8
    Nit-picking a little aren't we? lol
  9. Member toasters's Avatar
    Sep 17th, 2001
    Livermore, CA
    2011 VW Golf TDI
    05-08-2012 03:00 PM #9
    Quote Originally Posted by FUZE View Post
    Her: MAIN MENU!
    Me: Yes.
    Mine's even worse....
    Her: Main menu
    Me: Call Katie George
    Her: Would you like to call Katie George?
    Me: Yes
    Her: Calling Katie Blake.
    Me: NO NO NO! WTF! STOP! NO! WRONG PERSON!!
    This has happened to me a handful of times. Pretty annoying.
  10. Member Wastegate13's Avatar
    May 3rd, 2006
    SoFl
    2011 VW GTI
    05-08-2012 03:06 PM #10
    I wish there was a way to turn that button into a mute button. The voice commands are next to useless.
    APR||BAG RIDERS||CCW||OTHER STUFF
  11. Member FUZE's Avatar
    Apr 13th, 2004
    San Jose, CA
    05-08-2012 05:49 PM #11
    Quote Originally Posted by toasters View Post
    Especially when it's someone you haven't talked to for a while.
    If it connects you, you better pretend like you really wanted to call them.
  12. Member type17volkswagen's Avatar
    May 2nd, 2004
    Alexandria, VA
    All original 77 Rabbit; 12 Prius C; 13 Jetta
    05-08-2012 09:03 PM #12
    Quote Originally Posted by Wastegate13 View Post
    There is. If you use VCDS there's a setting in the BCM to disable it on the steering wheel. It will still work in the overhead console if your car is equipped. Best part, when you disable it for voice commands, it turns it into a mute button for the radio. At least that's how it works in my 2011 Jetta. I haven't done it in my 2011 Golf.
  13. 05-09-2012 10:55 AM #13
    So seriously, there's no simple setting to just turn her default voice down? Just seems really wrong the designers of that system would have it SO LOUD.
  14. Member Code3VW's Avatar
    May 5th, 2004
    Gilbert, AZ
    '10 CW JSW TDI 6MT
    05-09-2012 01:52 PM #14
    Her: MAIN MENU!
    Me: Yes.
    Press the voice command button
    Say "settings"
    Say "short dialog"
    It gets rid of the question, unless it can't understand you very well...then it will still ask.
    OEM+ Bi-Xenon HIDs | Front & Rear Fogs | Highline CECM | Euroswitch | RNS-510 HW:08 SW:1140 w/ Software VIM | Backup Camera | 9W7 | Dash Cubby | Aspherical Mirrors | GTI Steering Wheel w/ .:R Badge | GTI 6MT Shift Knob | GTI E-Brake Boot | GTI Pedals | GTI 18" Detroits
    Not so OEM+ Koni Coilovers | Gentex Homelink Mirror | Yaesu FTM-350AR
  15. Member ThreadBomber's Avatar
    Feb 4th, 2007
    Vancouver
    2011 GTI 2dr 6M
    05-09-2012 02:22 PM #15
    Quote Originally Posted by Code3VW View Post
    Say "settings"
    Say "short dialog"
    Yep.
    Also if I am understanding this thread correctly, in the Bluetooth module in VCDS there is an option to change the phone button on steering wheel to a mute buttton and then the one on the overhead still works? Sweeeet.
    Teefy Buna
    Quote Originally Posted by Sump View Post
    I'm sure a lot of these guys went home after the carwash and played a little hans solo.
  16. Member Code3VW's Avatar
    May 5th, 2004
    Gilbert, AZ
    '10 CW JSW TDI 6MT
    05-09-2012 02:24 PM #16
    Quote Originally Posted by ThreadBomber View Post
    Yep.
    I think it is in 16-Steering Wheel.
  17. Member ThreadBomber's Avatar
    Feb 4th, 2007
    Vancouver
    2011 GTI 2dr 6M
    05-09-2012 02:28 PM #17
    thanks I will check it out, would much rather have a mute button
    Teefy Buna
  18. Member Wastegate13's Avatar
    May 3rd, 2006
    SoFl
    2011 VW GTI
    05-09-2012 03:51 PM #18
    Quote Originally Posted by type17volkswagen View Post
    If this works I will buy you a beer.
  19. Member FUZE's Avatar
    Apr 13th, 2004
    San Jose, CA
    05-09-2012 06:58 PM #19
    Say "settings"
    Say "short dialog"
    Thanks brother
  20. Member RogueTDI's Avatar
    Dec 12th, 2002
    Victorville, CA
    2010 Golf TDI 4DR MT6 SB
    05-12-2012 08:28 PM #20
    I too just re-noticed this problem. That is bad enough. But combined with fact the same main volume is also the call volume, amd call volume is consistently low (on latest 9w7), its really irritating. Combine with the dropping out of BT stereo audio after 3 seconds of silence, and a couple other bothers, i miss the simple proper function of the 9w2 i upgraded from.
  21. Member rockerdan's Avatar
    May 21st, 2011
    Sanborn/Niagara,NY
    '12 GTI Autobahn,'04 Ram 4x4,'08 Harley Nightrod Special,'06 Yamaha Apex,'12 Arctic cat 1100 TURBO
    05-12-2012 11:26 PM #21
    Im sure this has been said.....
    but you can simply adjust the volume whenever the voice talks, the volume bar across bottom of my nav is green rather then red for radio.
    '12 GTI Autobahn 6SPD MT
    Red Footwell lights | Rear View Camera | CIM Boost Gauge | VCDS Tweaks | EuroCupholder | SeatDrawers | Chrome Glovebox latch | CandyWhite Spoiler | 'R' LED Tails | Euro HL Switch | 35%-20%Tint | Hartmann HROC 19x8.5 ET47 | Conti DW 225/35-19 | H&R Super Sports
    My Mod-DIY-Build thread! | Pics!
  22. Member intoflatlines's Avatar
    Jun 26th, 2008
    Chicagoland
    Z4 M Roadster
    05-12-2012 11:33 PM #22
    Quote Originally Posted by rockerdan View Post
  23. Member RogueTDI's Avatar
    Dec 12th, 2002
    Victorville, CA
    05-13-2012 02:36 AM #23
    Except that green volume is also in fact the call volume. So turning loud lady down makes calls too quiet, and vice versa.
  24. Member Tim S's Avatar
    May 7th, 2002
    '12 GTI 2dr TR Sunroof/Nav w/DSG
    05-13-2012 04:47 AM #24
    Yep.
    Uncheck Steering Wheel Module (16), Byte 01, Bit 3 "Multi-Function-Steering-Wheel (MFSW) with Push-to-Talk (PTT) Button installed"
  25. Member rockerdan's Avatar
    May 21st, 2011
    Sanborn/Niagara,NY
    05-13-2012 01:27 PM #25
    Quote Originally Posted by RogueTDI View Post
    I guess i dont see the issue..LOL, I just turn volume for each and everything up or down whichever thing im using. sorta common sense i guess?
    I do understand the complaint fully though, and im not sure of any way VW could have made it better then simply being able to adjust it.
    I was happy when i found the green volume when she speaks, cause originally i never knew it could be changed at all..lol
  26. Member type17volkswagen's Avatar
    May 2nd, 2004
    Alexandria, VA
    05-13-2012 02:49 PM #26
    I need a beer. Did this work for you?
  27. Member Code3VW's Avatar
    May 5th, 2004
    Gilbert, AZ
    '10 CW JSW TDI 6MT
    05-13-2012 02:51 PM #27
    I get a sip for this:
  28. Member Wastegate13's Avatar
    May 3rd, 2006
    SoFl
    2011 VW GTI
    05-13-2012 10:14 PM #28
    lol. Haven't had a chance to check yet. I was out of town for a long weekend and I haven't hit up my buddy with a VagCom yet. I've really been thinking of ordering my own since my wife and I both have VWs now.
  29. 05-15-2012 11:46 AM #29
    You can say, "settings" but there are no options for default volume. boo.
  30. Member
    May 26th, 2006
    Chattaboogie, TN
    2011 GTI #yolo
    05-15-2012 01:08 PM #30
    Why change it? I love the mad dash to ohgodihitthebuttonnowigottaturnthevolumedownbefore she...phew.
  31. Member RogueTDI's Avatar
    Dec 12th, 2002
    Victorville, CA
    05-15-2012 01:30 PM #31
    I used settings to set "short dialogue" but it made no difference to anything...
    On a related matter, who else find's the 9w7 in-call volume to be rather low? I can barely hear people on the other end at times, even with volume all the way up on phone and car.
