Results 1 to 11 of 11
Thread: Need help,stuck in gear
  1. Junior Member Shawn Biggs's Avatar
    Feb 25th, 2012
    Burton,MI
    1996 Golf GTI VR6
    05-06-2012 03:16 AM #1
    Daily 96 gti vr started to act up last night and now its stuck in 3rd and the stick will not engage at all,sorry complete noob here,hoping its not an internal trans issue
  2. 05-06-2012 05:33 AM #2
    Does the shifter move?
    If yes, I'd check the cables, maybe they got loose on you.
    If no, then you may be looking at a new clutch and/or a new tranny.
    Sorry if it's the 2nd one.
    Quote Originally Posted by DIAF
    Mass murders are so statistically insignificant that they should not be used as a basis for any policy, particularly any policy that would infringe on individual rights.
  3. Banned vento86's Avatar
    Oct 13th, 2008
    05-06-2012 05:45 AM #3
    Does the clutch have a good feel to the pedal?
  4. Member speedjohnson's Avatar
    Nov 27th, 2006
    Moultrie, GA.
    B4 wagon vr6 94 Jetta III GL 2.0 97 Jetta GLX VR6
    05-06-2012 12:33 PM #4
    I want to say you're about to buying a new transmission.
    I had something similar happen last year with my passat. Was stuck in 1st gear but shifter was in reverse. One of the gears on the main shaft in the tranny broke off and put everything in a bind. About $3000 later (tow/parts/labor/anal lube) I had a new solid tranny.
    But lets hope your shifter fork is broken or that you just need to adjust your cables.
  5. Junior Member Shawn Biggs's Avatar
    Feb 25th, 2012
    Burton,MI
    1996 Golf GTI VR6
    05-06-2012 01:05 PM #5
    Quote Originally Posted by dubraycer36 View Post
    Yes the shifter just moves around,clutch pedal has a good feel to it
  6. Junior Member BigRMart's Avatar
    Dec 9th, 2011
    Easton,MD
    98 jetta gls, 95 4dr golf sold, 89 jetta diesel sold
    05-06-2012 01:10 PM #6
    mine will do the same thing but it only happens when i clutch less shift
  7. Junior Member Shawn Biggs's Avatar
    Feb 25th, 2012
    Burton,MI
    1996 Golf GTI VR6
    05-06-2012 01:14 PM #7
    Quote Originally Posted by BigRMart View Post
    Ive only done a no lift shift once in the car and it drove fine afterwards,Im going to try and tear into it today,thanks all for any info/advice
  8. Junior Member Shawn Biggs's Avatar
    Feb 25th, 2012
    Burton,MI
    1996 Golf GTI VR6
    05-06-2012 01:28 PM #8
    Trying to find the DIY thread on adjusting the cables?
  9. Junior Member Shawn Biggs's Avatar
    Feb 25th, 2012
    Burton,MI
    1996 Golf GTI VR6
    05-06-2012 02:40 PM #9
    Id say I found the issue
  10. Member Ickey's Avatar
    Sep 6th, 2009
    Richmond IN
    97 Jetta VR
    05-06-2012 05:55 PM #10
    Yes u have Ur bracket broke ...cheaper fix ...bet Ur pretty relieved I know I would be
    Sent from my PG86100 using Tapatalk 2
  11. Junior Member Shawn Biggs's Avatar
    Feb 25th, 2012
    Burton,MI
    1996 Golf GTI VR6
    05-06-2012 06:50 PM #11
    Quote Originally Posted by Ickey View Post
    Much more relieved,I guess too much track time took its toll,lol.I have no doubt thats the original part and it was going to go at some point,just going to get one out of the yard even though if I had the cash a new one would be the smartest choice,think Ill have the linkage adjusted and change the gear oil while Im at it,grinding gears is not fun
