transmission code CDM, will bolt onto any 12 vr6![]()
#1
[IMG][/IMG]
stock trans available. case is perfect, everything works would require a second gear syncro to make it shift perfect without grinding second gear at high rpm, and the input shaft bearings replaced in the near future since its a lil noisy or just take the 3.64 ring and pinon out and put in in your transmission for the shorter ration that these stock transmissions come with
$175 o.b.o and flanges are included
trades welcome for a corrado or b5 audi a4
909-762-1833
