VWVortex.com - insane boost creep>>i cant stop it! help!
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 29
    Thread: insane boost creep>>i cant stop it! help!
    1. Member A2TDI's Avatar
      Apr 8th, 2004
      MK2 wannabe Drag car
      05-06-2012 11:02 AM #1
      setup
      built aba bottomend (2008cc)
      20v head ported with all springs, retainers and ferrea valves, and QED purple cams
      turbo: HX40 with BEP .70 ar ex housing
      precision 46mm wastegate (18 lb spring)
      CTS cast 4 into 1 t3 exhaust manifold
      this thing creeps like a MOFO! it spikes to 25 lbs instantly then raises to 35psi before 7000rpm and there is no boost controller and i have changed the boost source from being in the manifold to right at the compressor. I want to eventually have the car tuned at 30 psi but right now if i keep my foot into it it doesnt ever seem to stop climbing in boost. I had a tial 38mm gate on it and it was creep so i said hey ill buy a new much larger gate and my problems will be solved! I was wrong... A couple things i didnt mention is its running on 94 octane, water meth and the engine endures the constant strain of a built 3 spd auto..
      90 4 dr jetta 2L 20V PTE 6262 at 30 psi 10.95 @ 135 mph 2250lbs (94 octane pump gas street car)
    2. Member GinsterMan98's Avatar
      May 19th, 2008
      Panama City FL
      96 GTI VR6 08 Hyundai Santa Fe SE
      05-06-2012 01:57 PM #2
      Where is the WG placement on the manifold?
      98 GTI - Mustard Mayhem - 1/4 - 11.679@117.58mph - .8 bar - parted Timeslip
      96 GTI - Turbo Panda - 1/8 - 7.63@97mph - 1.1 bar of turbo fun!
      89 325is - New turbo project
      www.lugtronic.com
    3. Member VRT's Avatar
      Dec 8th, 2001
      Canada
      90 corrado 20/20 haldex, 2003 jetta
      05-06-2012 02:08 PM #3
      Wastegate is too to big. Creeping from there
    4. 05-06-2012 06:09 PM #4
      Quote Originally Posted by VRT View Post
      whatever dude. What does that even mean?
      It has to be some kind of wastegate issue. Either your placement (manifold design) sucks or it isn't passing air somehow. 46mm should be large enough to not creep like that unless it isn't opening for some reason.
    5. Senior Member TBT-Syncro's Avatar
      Apr 28th, 2001
      Vancouver
      92 VR-T syncro GTI, 2011 husaberg FS570, 2014 Aprilia Tuono V4 APRC
      05-06-2012 08:45 PM #5
      i'd start by replacing the vac/signal line to the wastegate.
      verify the dump tube isnt bent/collapsed/crushed/etc
      since those are two things that have stayed constant even with the wastegate change.
    6. Member therealvrt's Avatar
      Jul 21st, 2004
      ottawa ontario canada
      97 gti
      05-06-2012 08:53 PM #6
      The dump tube diameter should not be smaller than the wastegate opening.
      Probably not the issue but it would be good to change unless the tube was bigger than 46mm to start
    7. Member AJmustDIE's Avatar
      Dec 22nd, 2010
      Ocala, Florida
      97 Black GLX, RIP 97 White 8vT Jetta Trek
      05-06-2012 08:55 PM #7
      Wastegate too big? LOL.
      Seems like you would know how to run the lines because of the engine specs alone, but do you have the reference line on the right port? Someone has to ask lol.
      It's Timmy with mmmmMojo, i have returned
      8VALVETURBO - RIP White Jetta
    8. Member GinsterMan98's Avatar
      May 19th, 2008
      Panama City FL
      05-06-2012 09:12 PM #8
      Quote Originally Posted by AJmustDIE View Post
      Oh yeah, forgot about that on, lol.
      www.lugtronic.com
    9. Member A2TDI's Avatar
      Apr 8th, 2004
      05-06-2012 09:58 PM #9
      i have tried changing the vac\boost line to several diff locations including right onto the compressor housing. I am not running a dump tube right now just to put that out of the equation. I am thinking its the manifold design.. im thinking about changing back to the hx35 to see if the creep continues. I think maybe the engine flows so much more with the larger turbo that its out flowing the manifolds port to the wastegate. I want to port it to see if it makes a difference but the casting is fairly decent and somewhat thin and i am convinced it wont help.
      manifold in question.
      http://www.ectuning.gr/site/EShop/Pr...4-fcc229db1c95
    10. Member GinsterMan98's Avatar
      May 19th, 2008
      Panama City FL
      05-06-2012 10:14 PM #10
      That has good port location. Like said above, which port are you running the boost signal to on the WG?
      www.lugtronic.com
    11. Senior Member TBT-Syncro's Avatar
      Apr 28th, 2001
      Vancouver
      05-06-2012 10:27 PM #11
      but you have the signal line going to the correct port on the wastegate? (basic, but not so uncommon)
    12. Junior Member dslazin's Avatar
      Jan 13th, 2011
      oakland, michigan
      86.5/vw/scirocco 16v/83 rabbit gti
      05-07-2012 12:29 AM #12
      take an airline to the waste gate and see if it is getting stuck?
      prepare for the jump to lightspeed.. crap didn't hook up the nitrous yet!!!!
      http://www.chipsmotorsports.com
    13. Member A2TDI's Avatar
      Apr 8th, 2004
      05-07-2012 12:45 AM #13
      boost line running to the bottom port on the wastegate. and i had the car running and hooked an air line up to the boost hose and when i pushed air in the gate opened and the car got louder. Im very baffled right now....
    14. Member sp_golf's Avatar
      Nov 28th, 2007
      Toronto
      88 Golf 16vT
      05-07-2012 12:47 AM #14
      Quote Originally Posted by dslazin View Post
      x2 make sure it's opening all the way. I'm guessing you can hear it open on the car?
      SP Solutions
    15. Member V-dubbulyuh's Avatar
      Nov 13th, 2005
      Mk3 VRT, Mk4 VRT, Mk4 VRT, Mk4 VR, A3 VR, B6 3.6 4Motion, B5 1.8T
      05-07-2012 08:55 AM #15
      If that wastegate has a total of (3) THREE ports (two on the base and one on the top), make SURE that the second signal port on the side is capped off or you will blow that motor up. You should only be utilizing two of the ports, ie top for vac, one of the side ports for signal.
      Just a precaution but you were having the same issue even when using the Tial 38mm so your problem with creep is somewhere else.
      "OP sounds like a MKIV guy"
    16. Member B4S's Avatar
      Apr 16th, 2003
      Marionville, Ontario, Canada
      2002 Forester S, 1984 Volvo 244
      05-07-2012 05:54 PM #16
      Is the wastegate plumbed back, or just open to atmo without a pipe?
      1984 Volvo 244 DL...with carb.
    17. Member A2TDI's Avatar
      Apr 8th, 2004
      05-07-2012 06:40 PM #17
      its open to atmosphere and the lines are hooked up correctly and the second bottom port is blocked off. so i wonder what my other problem would be..when i had the hx35 on and the tial 38mm everything was fine and dandy! as soon as i put the hx40 on it was uncontrolable so i figured i would throw a larger wastegate on to cure it...that didnt happen...the engine is built for that boost and i want to run 30 psi but its hard to tune something that just keep climbing....i know it isnt right and i want to fix it.
    18. Member V-dubbulyuh's Avatar
      Nov 13th, 2005
      05-07-2012 07:04 PM #18
      If the spool of the turbo is overwhelming your manifold/wastegate setup it will creep/spike as you stated. You stated that your only change was the HX35 to HX40 when you first noticed the spike problems. You changed the wastegate and saw no improvement. On very fast spooling turbos sometimes the wastegate can not open rapidly enough to vent the boost causing a spike. When I have had that happen before I have had to relocate the wastegate closer to the collector. Not saying that this definitely is your problem but at least something to think about.
    19. Banned
      Jun 10th, 2011
      Fort myers
      05-07-2012 09:25 PM #19
      Deff check you capped a lower side port, then remove WG and make sure you put the sealing Ring, then if you open the WG to change spring re open and check diaphram for rips. Good luck.
      we have ran that manifold before at 26psi rock steady, not the dump tube, not the deisgn, not the set up. Re check the WG
    20. Member GTijoejoe's Avatar
      Oct 6th, 2001
      '06 Evo Mr, '15 CRV Touring, '16 Civic Touring
      05-08-2012 12:54 PM #20
      Quote Originally Posted by xtremvw3 View Post
      That is the right thing to do, look at the WG which probably is the problem. Do you have any smaller springs?
      Its best to try and tackle this issue with a smaller spring, because if you can't fix it by running less boost, it wont be fixed... and its the safer approach to fixing your issue.
      2.0T+034efi+meth = 300+whp = RIP
      FS: 2015 Honda Civic Si
    21. Member
      May 10th, 2011
      England
      Seat Leon Cupra
      05-08-2012 04:36 PM #21
      Just had a look at the manifold, it states it's for 38-39mm waste gates - how are you using a 46mm wastegate ???
      What is the diameter of the wastegate hole in the manifold at the wastegate flange ?
      If your using a 2 bolt 38mm wastegate to 46mm convertor then it'll probably flow no more than the 38mm one with the smallest size being the bottle neck.
      My Seat Leon Build Thread, 1.8T rebuilt to 2067cc Engine, 4wd Conversion & Borg Warner EFR 8374 Twin Scroll Turbo -
      http://forums.vwvortex.com/showthrea...R-Build-Thread
    22. 05-08-2012 09:18 PM #22
      Quote Originally Posted by GTijoejoe View Post
      Less boost will exacerbate the problem. I don't know what you're trying to suggest. The more boost he runs, the less will flow will need to be vented by the WG so it'll have an easier time.
      If you're really stumped you might even try removing the WG to see what your boost does. Or running it without the spring.
      Say for instance you remove the wastegate, drive the car, whatever boost you wind up spooliing is the minimum your wastegate port can possilby flow. Maybe add the WG without a spring next, to see how much a fully open WG can flow.
    23. Member GTijoejoe's Avatar
      Oct 6th, 2001
      05-09-2012 09:23 AM #23
      [QUOTE=tasty danish;77298365]Less boost will exacerbate the problem. I don't know what you're trying to suggest. The more boost he runs, the less will flow will need to be vented by the WG so it'll have an easier time.
    24. Member A2TDI's Avatar
      Apr 8th, 2004
      05-09-2012 07:20 PM #24
      i ported the outlet of the wastegate to 46mm and welded on the v band flange. I wanted to port the whole thing but i didnt think it would make too much difference. I have been thinking about cutting off the wastegate elbow and porting it out so i could fit a 90 degree stainless tube that would be the same inner diameter as my wastegate and weld it all up. what do you think?
    25. 05-09-2012 10:18 PM #25
      That's exactly my point.... He should be able to run low boost period, its a lot safer to fix a boost creap problem at 10psi than it is at 25 which he is currently at. As well as actually fixing the problem 100% at low boost is best, not just making it easier to fix the problem but actually fixing the problem. There is no reason why he shouldn't be able to run 8-10psi on his setup... something is seriously wrong.
      yes I agree he should be able to control the boost, however, it is more work for a wastegate to hold 8 psi, than 25. If he is getting creep at 25, he would get it, and more dramatic, at 8, though terminal boost would be the same regardless.
