Results 1 to 7 of 7
Thread: CEL
  1. Member turbodeluxe14's Avatar
    Nov 6th, 2010
    06 passat revo stage 2 w/ 3inch d/p with 3 inch straight pipe into magnaflow exhaust, lowered
    05-06-2012 07:41 PM #1
    so CEL came on a few weeks ago as it does here and there so got it scanned today and it said "cooling system to lean" anyone ever hear of this could it just be the mods throwing the light. car is tuned so i thought cel wasn't suppose to come on and no mods to the cooling system beside cold air intake thanks guys..
    Dec 24th, 2011
    Belleair, Florida
    2006 Volkswagen Passat
    05-06-2012 07:43 PM #2
    Quote Originally Posted by turbodeluxe14 View Post
    Do you have the fault code #? I've found that when I get fault codes ross-tech's page normally has something on it. If you do have it, post it and I'm sure another member will help. You could also google your code with ross-tech included in search.
    2006 Passat FSI 2.0T | Forge DV Spacer | 17" Monte Carlo Wheels | 10" Kicker sub in custom box | iPad Mini Dash installed as headunit | 5% Tint on sides, 30% on back window | Carbon fiber mirrors | Votex Roof Rack | Resonator Delete w/ Magnaflow tips | Badgeless grill | OEM Audi S6 LED DRLs | Lip spoiler
  3. Member najel's Avatar
    Apr 10th, 2008
    Mankato MN & Bielefeld Germany
    03 Jetta GL & 06 Passat 2.0t
    05-06-2012 10:07 PM #3
    I don't think the cooling system can be too lean. Code number would be very helpful.
    My guess is it said System too lean and it is a P0171 code. Could well be caused by your CAI since they sometimes don't get the part for the MAF sensor right, which leads to wrong readings.
    Owning a VW is like having a hot girlfriend that's mentally unstable
  4. Member turbodeluxe14's Avatar
    Nov 6th, 2010
    05-07-2012 07:30 AM #4
    Quote Originally Posted by najel View Post
    thats exactly waht it was that code.. so is it anything bad ??
  5. Junior Member
    Oct 2nd, 2009
    Columbus OH
    08 VW Passat APR Tuned
    05-07-2012 10:37 AM #5
    You could have a bad MAF, I was getting the same code when I installed the Forge WINTake. Buy a can of MAF cleaner from your local parts store and clean the MAF. I would at least start there and see if the code comes back.
  6. Member
    Nov 26th, 2011
    Lancaster, PA
    2007 Passat 2.0T
    05-07-2012 02:22 PM #6
    Check your PCV as well...my car threw that code when my PCV went...it has an extended warranty from the dealer until 120k I believe
  7. Member turbodeluxe14's Avatar
    Nov 6th, 2010
    05-07-2012 02:58 PM #7
    ok thanks alot guys ill let u know.. so when u did the MAF cleaner the cel went away?
