Results 1 to 3 of 3
Thread: Cracked Old C2 Y-Pipe Exhaust manifold...where to go from here? let's chat.
  1. Moderator DannyLo's Avatar
    Aug 2nd, 2006
    Long Island, NY
    Not Vortex Approved
    05-06-2012 08:14 PM #1
    Was driving along one day and heard a faint ticking sound when on throttle even out of boost. No one could hear it but me since I drive the car everyday and noticed the difference.
    Needless to say I put the car on the lift and started going at it with a flashlight while it was running to see if I see/hear anything. Nothing at all from the tailpipe forward until i get to the engine. I look straight up at the turbo and see a little black gash in the pipe. IIRC it's not even at the weld but in the middle of the pipe.
    Now my question to you guys is:
    I'm about to tear down to get it out and go from there. Should I try to weld, reinstall and then brace somewhere, or should I spend and change setup to a log manifold?
    I'm willing to bet it cracked because the original setup wasnt braced, and had the turbo sitting topside. However, it did last 2 years of abuse, so maybe if I weld and brace it, I'll get a bunch of more years out of it.
  2. Senior Member TBT-Syncro's Avatar
    Apr 28th, 2001
    Vancouver
    92 VR-T syncro GTI
    05-06-2012 09:35 PM #2
    i think braces cause more problems than they cure. I say clean it properly, weld it well, and make sure your motor mounts are good.
  3. Moderator DannyLo's Avatar
    Aug 2nd, 2006
    Long Island, NY
    Not Vortex Approved
    05-07-2012 02:12 PM #3
    Quote Originally Posted by TBT-Syncro View Post
    That's what I was figuring to do. My motor mounts are good, but they are factory on the engine and tranny side. BFI Stage 2 dogbone, so there is a fair amount of movement which you can see in my old dyno vid. Maybe I should upgrade all 3 to something a bit better.
