Did you line up the engine to TDC before taking off the timing belt? I've never had the pleasure of working with a 16v, but if you didn't line it up, I'm guessing you'll have to turn the block and head simultaneously to TDC before reinstalling the timing belt. Other (safer) option would be to take off the head, then set both head and block to TDC and reinstalling.
It's an interference motor, so turning one without the other will bend valves.
