2002 Audi A4 1.8t Quattro Auto/Tiptronic 116,xxx $6500, not looking for trades
Front and Rear Heated Seats, Sunroof, Full spare, Platinum Interior
Timing belt and waterpump were done at 76xxx
has had alot of maintence and have the receipts, second owner.
Engine: (have most stock parts)
Replaced ko3 with borg warner k04 at 106,xxx
Revo Stage II
TT 225 Injectors
Borla Exhaust
VMR Test Pipe w/ heat shield
Forge 007 DV
Forge TIP
FMIC
Intake
Koni Adjustable Coilovers (installed 96xxx)
RS4 rear sway bar
Apikol snub mount
awe vent boost gauge
s6 Shift Knob
6k Hid low beams/fog lights
A4 Sport Rubber Mats
20% Tints
Wires are run for subs and amp from previous system.
A8 Reps 18"(tires have 5k), had been resprayed so there is some chipping (have stock 15" rims, 2 have good tires)
It recently at 116,000 had an oil change, checked and fixed all boost leaks, as well as a serpentine belt and had the rear window regulators replaced. It also recently has had transmission flushed and valve cover gasket done within the past year.
Bad: Dash Cupholder is broken, made it into a little slot to hold my ipod
Armrest lid fell apart, so i took it off
Driver seat has the common cracking on the side closest to the door
Have not had time to take pictures of the interior yet but will with request, here is what I have on my laptop
(Grills are currently plastidipped black, rings still chrome)
