Results 1 to 5 of 5
Thread: SP head, manifold and K04-022 swap to make a 225 A4?
  1. Member jedge1.8t's Avatar
    Jan 27th, 2012
    Rocklin
    2001 TTQ 225
    05-07-2012 03:53 PM #1
    hey im building a stroker right now and considering sourcing a AEB head. i found a 97 a4 with head damage i can buy for pretty cheap and then got a idea.
    take the AEB head from the a4 and switch it out with my TT's AMU smallport along with the manifolds and KO4. The gain here is i get a AEB for my stroker TT and I also have a rebuilt A4 with the 225 TT characteristics, low end torque and more power with ko4.
    These are the issues i know of, but if you know more please chime in:
    head bolt size on AMU head, there made for m10 but i need m11 i believe, do i have to bore out?
    is the ko4 and manifold a different mounted position, meaning i cant hook exhaust up?
    I also realize i need a tune to take advantage of the ko4.
    2001 Audi TT Quattro 225 - 1400 watt kicker sound system, dynamatted, foamed frame, carpet jute adhesion, duralined trunk - APR stage 1, TIP, TFSI coils, WG spring mod, EVO9 DV, Tru-Boost, UEGO.
    Theres never an eternal gratification when it comes to making your car faster.
  2. Member Yak Meat's Avatar
    Sep 28th, 2011
    MA
    04 R32, 00 A4 1.8T, 88 911 Targa
    05-08-2012 03:49 PM #2
    You will need to bore the head to fit the m11s.
    As for the turbo, the mounting position and exit of the turbo is going to be all wrong and you will have issues with it. In all honesty your better off selling the ko4-02x along with the manifold, lines, and injectors for like 700-800 and going FT on the A4. Less headaches, same power, easier build.
    Garage Sale
    Nothing makes sense on this forum anymore. So I'm going to go masturbate.
  3. Member jedge1.8t's Avatar
    Jan 27th, 2012
    Rocklin
    2001 TTQ 225
    05-09-2012 05:24 PM #3
    i wonder if its possible to bolt it on backwards, even if not i could always go F4
  4. Member ray4624's Avatar
    Jul 23rd, 2010
    UMass
    98 a4 1.8tqm
    05-09-2012 07:27 PM #4
    bolt the turbo on backwards?
    the exit would then be facing the front so that wouldnt work
  5. Member jedge1.8t's Avatar
    Jan 27th, 2012
    Rocklin
    2001 TTQ 225
    05-10-2012 12:57 AM #5
    the ko4 exhaust would face the front if you bolted it on normally. but anyways it would probably be to much of a hassle
