Results 1 to 15 of 15
Thread: Removing light swirl marks by hand?
  1. 05-07-2012 05:52 PM #1
    Hey guys I am new to this whole thing but have been reading quite a bit on the topic. From what I have read, the best way to remove swirl marks is to use a rotary buffer with a good polish and pad combination. My question is if there is a product/way to remove the light swirl marks which were made last time i washed the car (wool mitt went bad on me and i didnt use 2 buckets like i usually do) by hand. I understand that it will probably take a while and be a pain in the ass, but i want to try it by hand before i invest in a porter cable. Would something like scratchX, applied 3-4 times sufficiently do the job? I am also looking at 3M ultrafina however that is what i would use with a rotary buffer.
  2. Moderator Jesstzn's Avatar
    Apr 20th, 2003
    BC CanaDUH
    05-07-2012 07:04 PM #2
    Rotary is a good way, but not the best way, to remove swirling but unless your well versed in its use .. you can install holograms which in turn will need to be removed with a PC .
    In reality unless you have gorilla arms your not going to get swirling out by hand. SwirlX has a lot of fillers and is intended for spot use etc etc .. And after a few washes your back where you started.
    The other thing is you don't "apply" polishes and polishes to be effective need to be worked until they break down, something you can't do by hand.
  3. 05-08-2012 07:21 AM #3
    Will require patience and a lot of ‘elbow grease’ but in some circumstances adequate results can be obtained
    Hand polishing is necessary around door handles, especially those that are recessed, around badges and emblems and around trim and panel edges, once masking tape has been removed and water drainage channel in trunk and hood.
    The application of detailing products with a random orbital has the advantage of ensuring an even consistent pressure and contact speed, mimicking free hand motion but at a far greater pace and a greatly reduced physical effort. By allowing the weight and the random motion of the machine do the work, thus ensuring that the product is applied in a thin even layer, and will allow products to get embedded deeper into the paint film surface's porosity.
    As a caveat I would say that very little correction can be accomplished by hand polishing, this is especially true with dense (hard) clear coat finishes like CeramiClear. If you are going to polish a large area by hand use a non-diminishing polish as they only require pressure, whereas diminishing abrasives require both kinetic energy (friction) and consistent pressure, which hand polishing cannot maintain over a long period of time.
    Plus you’re going to feel numb for a week if you try and polish an entire car by hand. What can be accomplished however is with the use of an abrasive all-in-one type product to remove defects such as surface water spots, oxidation, etc.
    ~ Providing unbiased advice that Professional and Enthusiast Detailer’s Trust ~ Blog -TOGWT
  4. Moderator Jesstzn's Avatar
    Apr 20th, 2003
    BC CanaDUH
    05-08-2012 09:29 AM #4
    I like that ^^^^ can I borrow it if I give credit ?
  5. 05-08-2012 07:23 PM #5
    its not so much swirl marks as light "swirl like" scratches. They arent necessarily in swirl pattern but are the same type of scratch. As of now I have seen them on the roof, hood and top of the trunk and wanted to try the top of the trunk before anything. I think i may just have to get an orbital polisher because the clear coats are so much stronger now.
  6. Moderator Jesstzn's Avatar
    Apr 20th, 2003
    BC CanaDUH
    05-08-2012 07:26 PM #6
    Quote Originally Posted by ReMiCkS View Post
    If you do .. invest in a good one .. the $30 Walmart ones won't do.
  7. 05-09-2012 10:42 AM #7
    Quote Originally Posted by Jesstzn View Post
    i would get a porter cable xp7424 or whatever they use on autogeek. the car is a metallic gray and while they arent easy to find, the fact that i can see them under direct like makes me think they are somewhat deep. I am going to try polishing by hand this weekend and then if it does not work will be investing in the buffer, pads and some 3m ultrafina.
  8. Moderator Jesstzn's Avatar
    Apr 20th, 2003
    BC CanaDUH
    05-09-2012 11:14 AM #8
    Have you researched the 3m ultrafina? Also before you buy pads do a little research there too .. a lot of these kits contain pads that are no help to you.
  9. 05-10-2012 10:47 AM #9
    a little bit. a friend of mine is a detailer and he recommended it. Which pads should i get?
  10. Moderator Jesstzn's Avatar
    Apr 20th, 2003
    BC CanaDUH
    05-10-2012 01:06 PM #10
    Did he tell you its for use with a rotary?
  11. Member
    Jan 4th, 2001
    07 V6 Passat Wagon--12 Golf 2.5 4DR
    05-11-2012 03:47 PM #11
    If you're going to purchase a Random Orbital it makes sense to consider the Groits Garage RO as it is the most powerful of the ROs and comes with a lifetime warranty. If you're just doing this as a hobby it covers you even if you only use it a few times per year.
    Detailers Domain (our sponsor) has some great packages that include 5 or 10 5.5" Uber pads (get 10 you'll need them) of your choice so you can pick what you'll need and includes a 5" backing plate. Uber pads have a recessed velcro which is an added margin of safety for beginners at machine polishing and they are flat pads which will give you the most correction with a RO. Rec: 4 Orange, 3 Green, 2 Bue if your car has soft paint for final finishing and a black for applying each LSP you plan to use.
    For polish you might want to consider UNO Advanced Cut http://cart.hdcarcare.com/polishes-compounds very user friendly, resonably priced and if your car has hard clear you may not even need the HD Polish as the UNO finishes down very well. Even if you do you're still only talking $45 for one 16oz bottle of each--they will last you a number of years as you will use very little. While you're at it their Sealant/Wax hybrid POXY is a great LSP--protection of a sealant the look of a wax.
    BTW--I polished my wife's Ford Escort by hand a few years ago using Megs 105--my arms are still numb.
  12. Moderator Jesstzn's Avatar
    Apr 20th, 2003
    BC CanaDUH
    05-11-2012 04:20 PM #12
    Quote Originally Posted by pwaug View Post
    How does Uno compare to Optimun for working time and dusting?
  13. Member Chalm's Avatar
    Jul 25th, 2006
    Cornbelt
    04' Jetta Wagon
    05-11-2012 04:21 PM #13
    I've been reading alot of positive reviews about the HD products.....still on the fence about making a purchase.
    Franklin Avenue Detailing
  14. Member
    Jan 4th, 2001
    05-11-2012 07:38 PM #14
    Zero dust. I have UNO V4 -- have done six passes with moderate pressure and two more with light pressure to finish down and it was still wet--wipes off very easy. My understanding is that the new version, UNO Advanced Cut, has even longer working time and stays clear.
    On my wife's Ford Escort (pretty hard clear) I can finish down with a B&S orange pad and be LSP ready.
    Since I've never used other polishes I can't say how it compares to Optimum and I didn't have any problems adjusting to UNO's characteristics--less is more (I used 3 dime size drops to prime and 1 additional per panel), it likes high speed rotation (5.5-6 on my GG RO) and slow arm speed. You will hear some people complain about the results they get, but it is usually pilot error--using UNO like other polishes they are accustomed to. The new HD Polish is for finishing mostly on soft clears and non-mettalic dark colors. HD Speed (AIO) looks amazing for an AIO--contains POXY which is a great wet look--have heard a couple of comments that it has more cut than PoliSeal and GPS -- waiting on my bottle now.
    Most successful user who posts allot on Autopia.org is thomasdekany -- look for his posts. Biggest problem HD has (IME) is they don't have an indepth "How to use UNO" video, which I believe is now in the works.
    I'm a little high on HD because I'm new to machine polishing and am having fantastic results as a beginner so take what I say with a grain of salt.
    UPDATE: THOMAS NOW WORKS FOR 3D. THIS IS A GOOD THING!!
  15. 05-13-2012 06:18 AM #15
    These articles may be copied and / or translated to your blog, newsletter, website, etc; providing the source is acknowledged thus - Copyright © 2002-2012, TOGWT® (Established 1980) all rights reserved)
    Detailing Articles - http://www.autopia.org/forum/autopia...yperlinks.html
