Page 1 of 3 1 2 3 LastLast
Results 1 to 35 of 84
Thread: Bluewater 3.2L 24V VR6 Billet Fuel Rails And Full Install Kits On Sale!
  1. 05-07-2012 09:34 PM #1
    Only $175.00 Buy Here
    In conjunction with 034 we are proud to announce the 3.2L 24V VR6 Fuel Rail. This rail is CAD engineered to facilitate optimal fuel delivery. Until now there has never been an option for running an aftermarket FPR and AN lines with the factory rail. These fuel rails are precisely CNC machined in-house from billet aluminum to ensure perfect fitment and the anodized black for a nice finish. The rail accommodates stock fuel injectors or short (48.8mm) bodied injectors.
    This is a great addition for high-horsepower turbocharged 3.2L 24V VR6 engines, and eliminates having to modify the stock rail to allow for larger fuel lines.
    What's Included:
    * Bluewater 3.2L 24V VR6 Fuel Rail
    * -6AN Fittings
    * Installation Hardware
    * We Also Have The Option To Add A FPR Adapter or To Purchase A Full Install Kit
    So everything Is Ready To Go!
    Fitment:
    * Volkswagen R32 3.2L VR6
    * Volkswagen Beetle RSi 3.2L VR6
    * Volkswagen Touareg 3.2L VR6
    * Audi A3 3.2L VR6
    * Audi TT 3.2L VR6
    Please Note: Does not fit the 2.8L 24V VR6 found in the Volkswagen Golf/Jetta/GTI/GLI.
  2. Member rajuncajun37's Avatar
    Apr 25th, 2008
    New Orleans
    2011 FORD .:Raptor
    05-07-2012 09:46 PM #2
    soooooo sexy
    *R32 1518*, biggest head ever to fit in a GOLF!
    Congrats, turd burglar.
  3. Member newcreation's Avatar
    Nov 23rd, 2003
    HBG, PA
    04 R32
    05-07-2012 09:54 PM #3
    Yikes
    -JAMES-
    Daily Drive /Beaten/Built /UM Turbo R - VR NATION
  4. Member Draxus's Avatar
    Jan 6th, 2009
    Seattle, WA
    MKIV DBP .:R32
    05-07-2012 11:13 PM #4
    1. What is that hexagonal block on the left?
    2. I assume that this connects to the top left plastic fuel line by the coolant ball? Is there a way to get a custom length?
    Quote Originally Posted by BlownR View Post
    I have seen several open slots, usually after tequila. Wait, I think that's different.
    MKIV DBP .:R32 | Photo Gallery
    Projects | Custom Exhaust : It Begins | Solid MKIV Sub-Frame Mounts ||Build Journal| Draxus's GoKart
  5. Member huichox4's Avatar
    Nov 8th, 2004
    83 Rabbit - 02/04 .:R32 Jetta wagon - 04 .:R32 - E30 325i & Alfa GTV6 Chumpcar Racecars
    05-07-2012 11:20 PM #5
    Quote Originally Posted by Draxus View Post
    1 fuel pressure regulator adapter,
    2 dont know it looks like it might need an fittings maybe to plug in to an IE surge tank or something
  6. 05-07-2012 11:21 PM #6
    1.The hexagonal block on the left is the fuel pressure regulator adapter which allows you to utilize the stock FPR.
    2. Give us a call if you need a custom length as well. We can accommodate any size that you need. (303)-800-7193
  7. Member Draxus's Avatar
    Jan 6th, 2009
    Seattle, WA
    MKIV DBP .:R32
    05-07-2012 11:27 PM #7
    Quote Originally Posted by gabe@bwperformance View Post
    Do you have an image of the FRP installed? I am having a hard time visualizing it. haha
    Thanks!
  8. 05-07-2012 11:34 PM #8
    Thanks!
    We have one installed, Will post a picture tomorrow!
  9. 05-07-2012 11:36 PM #9
    Quote Originally Posted by huichox4 View Post
    The lines do connect to the stock fuel line quick connect fittings which are by the coolant resivor.
  10. Member rajuncajun37's Avatar
    Apr 25th, 2008
    New Orleans
    2011 FORD .:Raptor
    05-07-2012 11:42 PM #10
    could you guys make the power steering lines that run from the rack over the transmission and I believe attach to those hard cooling lines. Mine leak
    I just need the rubber line that attaches at the rack, it leaks where the rubber meets the metal.
  11. Member DarkSideGTI's Avatar
    Aug 11th, 2001
    SL,UT
    Bagged R32T
    05-08-2012 11:08 AM #11
    Is it just me or does the FPR look like it is before the injectors? O wait you reversed the flow right?
  12. 05-08-2012 11:39 AM #12
    Quote Originally Posted by DarkSideGTI View Post
    Yes the flow is reversed. The fuel comes in at the drivers side and the FPR is at the passenger side.
  13. 05-08-2012 11:41 AM #13
    Quote Originally Posted by rajuncajun37 View Post
    I think we could make those but the challenge is to make them for less than the factory one which is $250.00 I made some custom lines on our old NA R32 I will try to go through my notes to see how much I can make them for.
  14. Member Rmeitz167's Avatar
    Dec 15th, 2007
    NEPA
    tred r33t
    05-08-2012 01:29 PM #14
    Im down for a set too that would delete the cooler and res so i could run an aluminum one.
    WunderWagens June 10,2012 in Gilbert, PA... 2nd year http://www.wunderwagens-show.com
    UnitedMotorsport r32 cam flash... get one
    My Turbo .:R Build Thread
    WunderWagens Vortex Forum
    WunderWagens Facebook
  15. Member Draxus's Avatar
    Jan 6th, 2009
    Seattle, WA
    MKIV DBP .:R32
    05-08-2012 04:16 PM #15
    Quote Originally Posted by hollywood@bwperformance View Post
    Friendly reminder.
  16. Member AsianR32's Avatar
    Jul 29th, 2009
    NoSide, Jersey
    2008 VW R32 (sold) ; 2004 VW R32 (current)
    05-08-2012 08:38 PM #16
    This will work with just a NA setup?
  17. 05-09-2012 12:42 AM #17
    Quote Originally Posted by AsianR32 View Post
    Yes it will work with just an NA setup. 😊
  18. Member itouch's Avatar
    Oct 14th, 2007
    MK5 R32T
    05-10-2012 04:05 PM #19
    What is the price for the full ready to go install kit including FPR adapter?
    Boosted RTHIRTY2
    UnitedMotorsport
  19. 05-10-2012 04:16 PM #20
    Price is $420.00 for everything like as shown. Which is a hell of a deal since we used to charge $400 for a rail and labor to modify it to accept AN fittings.
  20. Member itouch's Avatar
    Oct 14th, 2007
    MK5 R32T
    05-10-2012 04:45 PM #21
    Thanks, is a 4 bar fpr in the price?
    Boosted RTHIRTY2
    UnitedMotorsport
  21. Member Rmeitz167's Avatar
    Dec 15th, 2007
    NEPA
    tred r33t
    05-10-2012 11:34 PM #22
    i dont think so
  22. Semi-n00b
    May 27th, 2011
    DeRidder
    2004 R32, 05 F250 PSD, 10 honda VFR1200
    05-11-2012 01:07 PM #23
    What benefits would there be to putting this on a NA car? Just curious.....
    TIA
  23. Member jcstomper's Avatar
    Feb 24th, 2002
    Philadelphia, PA
    04 .:R, 07 MB C class Daily
    05-18-2012 10:11 PM #27
    sweetness! im sold!
    .:R 13.57@100MPH... on 19's
    Old Car.. 1.8t GTI stock turbo, street tires.....13.58@103MPH
    www.facebook.com/Jcstomper,Bucks County Roof Cleaning,Low Pressure Roof Cleaning..
    My turbo build
  24. 05-22-2012 03:09 PM #28
    Quote Originally Posted by itouch View Post
    No you will just use the stock 4 bar FPR in your current setup.
    Quote Originally Posted by bootcamp View Post
    TIA
    Honestly in an NA car there are no real added benefits unless you are wanting to run AN lines or are just in it for the looks.
    Quote Originally Posted by jcstomper View Post
    sweetness! im sold!
    haha Awesome!
  25. 05-23-2012 10:40 AM #29
    Gabe,
    Ok have I really turned dumb or am I missing something here. How do I login to your website to place an order, i cant find where to register my log on?
    Also will -6AN fittings and -6AN fuel lines support 650bhp? Or should i go for -8AN?
    RHD T60-1 stage 3 VR6 Specialist mapped.
    Build thread http://www.r32oc.com/topic/14007-stage3-turbo/
  26. Member
    Jul 11th, 2011
    Colorado
    mkiv r32
    05-23-2012 11:13 AM #30
    TIA
    I just got one put on my NA car, I'll post pics later.
  27. 05-23-2012 07:51 PM #31
    Quote Originally Posted by climiefish View Post
    Gabe,
    You do not need to login to order. Also, -8AN will work better for 650bph...
    Quote Originally Posted by Norkoth View Post
    Whooo great to hear!!
  28. 05-26-2012 09:14 PM #35
    Happy Saturday!!
    Happy Sunday!! From China!
