VWVortex.com - Suspending 42 inch tv from ceiling?
    Results 1 to 8 of 8
    Thread: Suspending 42 inch tv from ceiling?
    1. Member HI SPEED's Avatar
      Sep 3rd, 2004
      Honolulu
      05-07-2012 11:53 PM #1
      We are getting close to closing on a small home, in the city. In order to use the space efficiently, we will need to be creative. We want to have a tv that disappears when not in use. The plan is to take down the wall that would naturally be the place to mount a tv, to make the home open floor plan. My thought is to tap into a beam along the ceiling and have a the tv drop down when needed, then move back up when not in use. It would be a bonus to be able to control tilt, but not a necessity.
      I have been googling around for ceiling tv mounts. They make many different kinds, but none seem to telescope. My thinking is that I may need to mount some pulleys up there. I have seen videos of motorized tvs popping out of hidden locations. Does any company sell a ready made solution, or do you need to cobble together something.
      Even if the solution was just a manual crank with pulleys I would be open to any design ideas. Without actually measuring, I'm guessing the tv will need to raise/lower 6 feet. The other challenge is that the roof is at a 20 degree angle.
      Would just making a sheet of metal that lined up with the mounting holes, an then attaching hooks to the sides be a strong enough solution?
    2. Member HI SPEED's Avatar
      Sep 3rd, 2004
      Honolulu
      05-07-2012 11:56 PM #2
      An extra bonus would be the ability to mount satellite speakers on the sides of the tv as well.
    3. 05-11-2012 12:27 PM #3
      I'm sure you could rig something up.. they make some light 42" lcd's these days. I don't really know much about automatic mounts, but I suspect they are overly expensive. The only thing I'd say about using a piece of sheet metal behind the screen is to make sure you don't block any ventilation holes.. tv's get hot and need airflow. Might be better to start with a standard mount that you can scew to the TV, then rig up something to attach to that.
    4. Senior Member SAPJetta's Avatar
      Feb 3rd, 2001
      East Bay, CA
      2008 Rabbit S(low), 2012 Outback 2.5 Premium
      05-11-2012 06:54 PM #4
      Where are we going and why am I in this handbasket?
    5. Member GreenandChrome's Avatar
      May 24th, 2002
      No one cares how you feel.
      DD: Big & Black O: A4 | Uncertified Preowned: Explorer, Sportage, xB, Golf GL
      05-16-2012 05:15 PM #5
      projector and a pull down screen.
      /done.
      Professional Thread Derailer | I have mixed drinks about feelings | I said 'good day'!
      Default post options: So, it has come to this. | If you think so. | Not that there's anything wrong with that. | That's what she said. | WTF.
      //// @mbull //// instagram ////
    6. Member
      Nov 10th, 2002
      NJ
      05-21-2012 03:49 PM #6
      Yeah, that prbebly the easiet way, even an auto-roll down projection screen would work well too.
      Quote Originally Posted by GreenandChrome View Post
      /done.
      Current: 2015 RPGM Chevy SS Sedan 6spd - 2000 Chevy K2500 - 2013 Honda Odyssey TE
      Past: 2011 JSW TDi 6spd @100k - 2006 Honda Accord Sedan V6 6spd @170k - 04 VW Passat W8 6spd Wagon @123k - 1996 Mazda Miata 5spd Base @257k - 2003 Jetta GLI 24v 6spd @74k - 1993 Jeep Grand Cherokee V8 @303k - 1991 Honda Accord LX 5spd @151k - 1993 Toyota Corolla 5spd Base @154k
    7. Member HI SPEED's Avatar
      Sep 3rd, 2004
      Honolulu
      05-21-2012 04:08 PM #7
      The entire wall facing the tv is windows. Otherwise I would gladly go 1080p projector. Found a few flip down mounts online. I need to get in there and do final measurements but I think it will work in between the joists. Not quite as trick as what I originally wanted, but it will be more practical from a cabling standpoint. Still contemplating a custom solution if time permits.
      Nov 10th, 2002
      NJ
      05-21-2012 05:40 PM #8
      So the TV is on the opposite side of the windows? Nothing a couple of shades/blinds can't fix.
      Quote Originally Posted by HI SPEED View Post
