VWVortex.com - Proper Offset
    Results 1 to 12 of 12
    Thread: Proper Offset
    1. n00b dped's Avatar
      Apr 30th, 2012
      Queens NY
      2012 VW CC Sport
      05-08-2012 01:19 AM #1
      I am thinking of purchasing Audi R8 wheels for my 2012 CC. The wheel is 18" with an offset of +40. How would that fit on the CC? I have stock suspension, btw. thanks alot guys
      Jan 31st, 2005
      Jacksonville, FL
      2009 CC Lux
      05-08-2012 01:54 AM #2
      Quote Originally Posted by dped View Post
      It would fit just fine. IIRC, the stock 19x8.5 Sagittas are ET41.
    3. Member snobrdrdan's Avatar
      Sep 10th, 2008
      Southeast Michigan
      2017 VW
      05-08-2012 08:09 AM #3
      Quote Originally Posted by InvertedB View Post
      All OEM CC wheels are 8" wide & ET41 (so 19x8" for the Sagittas)
      As for the proper offset...40 would work, easily, assuming it's a 8" or even a 8.5" wide wheel
      2016 Tiguan R-Line
      2017 Passat R-Line
    4. n00b dped's Avatar
      Apr 30th, 2012
      Queens NY
      2012 VW CC Sport
      05-08-2012 10:51 AM #4
      thanks alot guys. Much appreciated
    5. Member FastB7S4's Avatar
      Mar 28th, 2008
      PA
      15 Lexus RC-F, 11 Touareg Sport, 15 Kia Sedona SX-L
      05-08-2012 10:17 PM #5
      How do you define "proper?"
    6. Member snobrdrdan's Avatar
      Sep 10th, 2008
      Southeast Michigan
      2017 VW
      05-12-2012 06:45 AM #6
      Quote Originally Posted by FastB7S4 View Post
      Well no rubbing on the strut or fender I guess, lol
      2016 Tiguan R-Line
      2017 Passat R-Line
    7. Junior Member
      Aug 8th, 2012
      2012 VW CC Sport
      08-18-2012 06:10 PM #7
      I fell in love with this rim but only found I picture of a CC with them. The are a 19x9 with a 33+ offset. I wanted them for my 2012 CC which recommends a 40-55+ offset. My wheel guy said this could cause a lot of issues due to less padding and possible rubbing on front turns.
      Thoughts or suggestions? This may explain why I have only found 1 picture of a CC with this set up
    8. Member FastB7S4's Avatar
      Mar 28th, 2008
      PA
      08-18-2012 08:39 PM #8
      Quote Originally Posted by mtc725 View Post
      With a 9" wide wheel and 33mm offset, you could be looking at rubbing issues. Fronts would be close, rear would probably poke. Are you lowered at all? I would think stretched tires are a must for this set-up.
    9. Junior Member
      Aug 8th, 2012
      2012 VW CC Sport
      08-18-2012 08:45 PM #9
      I am going to be lowered on Eibach por kit for now until I get coil overs, but this set up sounds like it is begging for problems. This wheel does not come in the proper off set and I have yet to find a replica or one that even comes close
    10. Member FastB7S4's Avatar
      Mar 28th, 2008
      PA
      08-18-2012 08:49 PM #10
      I'm no expert but just sounds like a borderline wheel. There are a few guys running 20s here and I imagine that those are at least 9" wide and probably around a +35 offset. Try asking your question in the wheel/suspension thread. The Savannahs are nice looking for sure.
    11. Junior Member
      Aug 8th, 2012
      2012 VW CC Sport
      08-18-2012 08:52 PM #11
      Thanks I did, and the feedback seems to be it's not recommended. This wheel is a 19". I appreciate the help though
    12. Member FastB7S4's Avatar
      Mar 28th, 2008
      PA
      08-18-2012 08:55 PM #12
      Right, I'm just saying that there are guys with 20s that fit and 20s usually are at least 9" wide so the 19x9 Savannah may fit.
