Results 1 to 14 of 14
Thread: FS: 5 speed Diesel Transmission swaps for every one. MK1 MK2 MK3.
  1. 05-08-2012 07:30 AM #1
    2 ways to go about looking at this add.
    1, I have replacement Diesel Transmissions for your busted up Diesel transmission.
    2, I have 5 speed Diesel transmission swaps for your GAS car to save fuel at highway speeds.
    Heres what I have. All O2O. All in good working order. no grinds, no problems. These will fit the 1.6 NA, 1.6 TD, and 1.9 TD mechanical Diesel engines as well as 1.8L 8V and 1.8 / 2L 16V gas engines with small spline clutches. These lower RPM in 4th and 5th gear considerably on Gas engines to save fuel.
    1, FN coded mk1 5 speed from 1.6 D. SOLD
    2, AWY coded mk2 5 speed from 1.6 TD. SOLD
    3, DPF coded mk3 5 speed from 1.9 TD. SOLD
    4, CHD coded mk3 5.speed from 1.9 TD. SOLD
    $300 Per transmission picked up in Oshawa. can deliver for gas money.
    Price is Firm, but I can include Fly wheel, shift rod, box, linkages, speedometer cables, clutch cables, mounts, if you need them in the price.
    Hasan
    905 244 7789
  2. 05-11-2012 11:39 PM #2
    DPF MK3 Transmission SOLD.
    Hasan
  3. 05-31-2012 10:05 PM #3
    FN MK1 Transmission SOLD.
  4. 06-01-2012 06:48 AM #4
    Quote Originally Posted by B3VW Hasan View Post
    Price is Firm, but I can include Fly wheel, Clutch kit, shift rod, box, linkages, speedometer cables, clutch cables, axles, mounts, if you need them in the price.
    Hasan
    905 244 7789
    good seller and straight up vortexer that knows his stuff
  5. 06-04-2012 08:29 AM #5
    Hey Phill.
  6. Junior Member
    Jan 17th, 2010
    East Thetford, Vermont
    MK3, MK2
    06-28-2012 04:56 PM #6
    Do you have any AVX, or 4spd 4A?
    Pete
  7. 06-28-2012 11:07 PM #7
    the only 4 speed manual I had for a 4K.
    Do you have an Eco Diesel mk2?
    I don't have the AVX, but I do have the AWY listed above. yes it has higher ratios in 3rd, 4th, and 5th; however, the final drive on the AWY is much lower than AVX.
    End result. 3 km/h of difference in top speed at 4500 rpm in 5th.
    Let me know if you'd be interested in my AWY.
    Only other Diesel 5 speed I have is an O2A mk3 B4 TDI / B3 TD hydraulic clutch, cable shift CHA. complete swap minus the pedal cluster for $500.
    This would go nicely on a 16V 2L. keeps the RPMS Low on cruising speed, but can take the punch when you want to do 260 km/h in 5th at 5000 RPM. given, the 16V is tuned. I don't know what the top speed would be, the speedo runs out at 260.
    Hasan
  8. Member MikeyG1976's Avatar
    Apr 4th, 2011
    Ontario, Canada
    White 13 Jetta Highline, Red 86 Jetta GLI 8v, Gold 87 jetta
    06-28-2012 11:45 PM #8
    I might be interested in that AWY I need a complete swap for a auto 87 jetta you have all that?
  9. 06-29-2012 11:02 AM #9
    I have everthing for a swap except for the pedal cluster. give me a call and I'll give you details.
    Hasan
    905 244 7789
  10. 08-03-2012 04:34 AM #10
    Sale pending saturday on the AWY.
    Also have a CHD mk3 TD transmission for 300.
    Hasan
  11. 08-06-2012 06:00 AM #11
    The AWY sold.
    Complete CHD 5 speed swap available for 400 minus the pedal cluster.
    Has shifter box, rod, linkages, clutch cable, mount, flywheel. No clutch.
    Extra 100 is for a very low milage big fat heavy duty diesel starter.
    Hasan
  12. Member tigers77's Avatar
    May 22nd, 2006
    Markham, ON
    2007 Rabbit
    08-08-2012 09:08 PM #12
    bump for you!
  13. 08-13-2012 09:03 PM #13
    Sold the chd at 6 am this morning.
  14. 09-30-2012 09:58 PM #14
    Happen to come across another ACH in a car with 205,000 km on it. seems to be running fine in all gears, and reverse, but I only drove it for 30 minutes. Drained the oil, it needed changing, but not Dirty from Hell.
    I seek $300 with axles.
    OR, $400 for complete 5 speed Swap.
    Hasan
    905 244 7789
