Results 1 to 5 of 5
Thread: Motorsport Shifter From Scrap
  1. Member gtiboy66's Avatar
    Jan 1st, 2000
    Toms River, NJ
    1978 Rabbit, 82 Jetta, 58 AH Sprite, 67 Morris Woody
    05-08-2012 09:59 AM #1
    So I decided that I wanted to put a motorsports style shifter in my car.
    I had a friend who had an All Smiles shifter which is just like the VW Motorsports ones from the 90's
    So I decided to replicate it.
    I did this with 50-60 year old machines all by hand.
    Total cost so far $0
    The shifter is basiclly 3 main pieces plus the cables.
    So far I have 2 done
    starting with a rough cut block
    done.
    I machined the main pivot hole larger for use with a brass or nylon bushing
    2nd piece
    done
    last piece I need to make is the shifter rod.
    Going to get working on this soon I hope.
  2. Member poopie's Avatar
    Feb 21st, 2005
    Philadelphia, PA
    05-15-2012 08:34 PM #2
    looks good so far. thanks for sharing
  3. 05-15-2012 08:58 PM #3
    Sent from my iPhone using Tapatalk Reihenmotors
  4. Member Unit01's Avatar
    Dec 26th, 2008
    Las Vegas
    Mk1, Mk2, Mk6 and some E30's.
    06-15-2012 05:25 PM #4
    Wow, I'm impressed. What tools did you use to cut that?
  5. Member gtiboy66's Avatar
    Jan 1st, 2000
    Toms River, NJ
    06-18-2012 03:46 PM #5
    Quote Originally Posted by Unit01 View Post
    I used a bandsaw, bridgeport mill and a big disc sander.
    I used a lathe to make the bushings and will use the lathe for the shift rod.
